Builds '81 Trekker ReDistruction
That could be Austin's first car. Think how proud he would be when pulling into the high school parking lot.
Molly and I have this don't ask don't tell policy. She dosent ask about the truck. I don't ask about her shopping.
Hi Theo, ripper set of Adidas!
Nice tube work!!
Picking away at it, I sorted all the parts, and re-sorted. Started cleaning things and the truck itself.
Found all the hardware, soaked it in wd40.
Like Toyota forensics, trying to decide which bolts Mr. T wanted where.
@jamarquardt22 tossed me a booster for a v6 truck a while back. He said it should bolt right up. I though it would interfear with the steering joint at the firewall.
Finally got them side by side, looks like Mr. T provided a spacer on the stock booster.
I'm gonna try and swap the studs over tomorrow.
If they go, it should work.
If I knew I would tell you. I kept all that. But that looks real crusty. Are you emissions exempt? If not your going to need it for inspection.
:frown:
Thanks for the reply.
You don't know the good ol'boyz I know. :cheers:
Anywho, no inspection needed to wheel Rousch/AOAA.
So, I ask again, anyone with any insight here?
Can I run without the canisters?
Start plugging vac lines?
When I can, I'll sit down and read the minitruck FAQ over on Pirate.
I don't know what the small one is either...
A proper desmog is going to be tough with the factory carb. Don't know that I have seen this info out there on the web like it is for cruisers.
I would keep a charcoal canister to vent your gas tank properly without smelling.
I have a box full of them - sure there is something in there that would work. How many ports are on it, and what is the distance between the holes on the bracket?
Have you thought about a Weber? It used to be a common swap.
