81 BJ42 - I have to bring it home and pass inspection
Those light models are of these .... I wanna use them cuz they're so purty. Got'em from mot long ago.
Errrr, here, mobetta.
Those are nice. Are they made by Koito?
I vote you drill all the holes to put all the lights.
Then...add lights as needed.
Amps shmamps, you can biuld a double alternater bracket easy
build a bull bar type thing. I think you'll be fine mounting them right in the center but I don't like how close they are together. Is clearance from your winch going to be an issue?
I also do not like the look of lights just under the factory ones.
I agree with cooling but at the same time I have never had issues and not to mention there are guys running 3 lightforce 240s on the front of their cruisers in Aus not having cooling issues.
drill, doesn't mean you have to use them.
plus, it seems LED is all the rage these days so a nice 15" across the top, your purdy fogs down under or outer top main beam.
done.
so what is going to be the price on the main beam when completed?
I just have to pay for material.
I already decided to put the lights in the outer location but I'll put both sets of holes in anyway.
They would be fine in the middle but I think they are too big in proportion to the bumper. At least on the screen, might be different on the truck. Not sure about where they are in relation to the headlights. It will be test fitted before full weld and powder. Might have to drill more holes.
One common thing I've noticed about almost every bumper design aside from the stock or straight bar types is that they all seem to seriously block the dumb headlights . Why do that ?? Can't anyone make a design that would protect the nose of the 40 in an animal strike and not interfere with turn signals and headlights ?
Good score on the fog lights , those are too cool .
Sarge
I think the bumper looks great.... But on this truck with everything else looking stock I think it might be cool to have the ends of the bumper curve in reminiscent of the OEM unit rather than the flat bent style you have going. The flat bend is done out of convenience usually. The curve would really kick the design into new territory as opposed to looking like what is already out there. Kinda like if the original bumper could actually bump stuff.
Just my $.02.
Pete
Pete, I had thought of that but drew it up this way cuz I was on a roll and just went with it. I might draw a version with stock lines just to see what it looks like.
Been working too many hours lately. Not much energy left at the end of the day to work on the 42. Just signed up for Cruise Moab so I'd better get her on the road and the bugs worked out.
To that end...
When last we saw the 42 I had opened up the bib and decided to fix it. I cut out the rust which fortunately was just getting to the two rad openings. If left to rust a little longer I would have had more work in replicating the edges of the openings. As it is I had only to make two angles, one from 16 ga for the outer layer (shoulda been 18 ga actually) and one from 14 ga for the inner layer. I simply made them both 24" long and roughly 1.5"x1.5" each.
I then took it to the shop where we have a bigger bead blast cabinet. I blasted the rust away from the weld area. Very important when the remaining material is so thin to have no contamination to fight with while welding. I also "fogged" the remainder of the bib to essentially "sand" the finish for primer adhesion. I did take any rusty spots down to metal. You eagle eyed lurkers will see the rust apparent in the bottom left. That was hidden under the end of the inner angle when I was blasting.
The backside is pitted but the front is good.
Just my $.02.
Pete
That would be way cool!
On my bib one of the plastic headlamp adjusting sockets broke. Anyone replaced these before? Is there a Toyota part# for it?
This was the worst spot. It blew a hole when I was welding it but I was using the Silicone Bronze filler rod with the TIG and just filled it up again.
The two angles
Hello, may name is Kevin and I have a clamp fetish.
I clamped it down to a flat surface and spent a half hour trimming the 16 ga angle to fit as flush as possible to the cut I made with the grinder.
Just trying to make sure the whole thing is as flat as possible
I tacked it with the TIG using steel filler rod (70S2 in 0.045" Dia). I then was curious and had to take off all the clamps to have a peek.
