81 BJ42 - I have to bring it home and pass inspection
I clamped it down again and welded the entire seam with the bronze rod and the TIG. This stuff melts quick and varies from a ball on the surface of the material to spreading out flat depending on the amount of heat you give it. Its a challenge to make pretty welds with. These will be fine, I'm not planning to grind them.
That chunk in the middle is that "worst spot" I mentioned above.
Welding from the backside was the only way I could clamp the part flat while welding. It creates a potential problem in that the other side is the cosmetic side and typically the backside of a weld is kinda not as pretty as the front. That was one reason I used the bronze rod. Given enough heat it will flow through and out the other side so that there is no pitting on the back. Which ends up being the front, so to speak.
Finished weld before grind and sanding
The flow through of the bronze
This is that blow out worst spot I keep typing about
After grind and sand. A couple of low spots but nothing a little spot filler and high fill primer won't hide. Not done yet anyway. I have to weld the inner piece in and that will mess up the face again.
Tacking the original ends to my replacement angle
Welded up. I took it from here and punched holes on both sides of the angle to weld through to the bib.
Test fitting
After welding in the inner angle I put the bib back on the truck to locate the hinge holes. I marked and drilled all three and then welded nuts on the inside.
Ready for bodywork tomorrow
Now, while I was busy making a lot of noise grinding and running the compressor, my son was getting his angry bird on
Thanks Gus, I'll let him know you approve. I always encourage creativity in my kids even though it usually cost me money at the craft store and makes a mess that I have to clean up.
Your wife probably says the same about you and junkyards.
I KNOW mine does. But I keep her well stocked in fine wools for knitting, and a big pile of firewood to keep warm, and she puts up with it. :grinpimp:
I don't know what you're complaining about with that rod. The repair on the bib looks fantastic!
Dan
Dan
Not to mention the level of mechanical perfection to which you keep Dammit....(Dan's wife's 4 Runner)
Right side rear brakes are wet. Shoes look a little thin too. I'm taking the drums into the shop to measure them and see where they are at.
Frame painting for Cody
Unmasked
And prettied up
Installed the Vac tank - Did find the sending unit after searching everywhere.
Had to move it over to get more room to shoot the pass side so I let her run for while and took some poser shots
A little over 12". So the tent should fit but the ladder prolly won't
Wayne was too smart to take me up on that bet. Are you sure you don't want to clean up the frame rails just past the bib? Everything else looks so new in comparison!
What did you paint the frame and bumpers with?
Stellar job......... let me know if you do that bumper and also if you are interested in building up an extra:beer::beer:
Rob
This is not a frame off.
Ha! The only difference is that you will enjoy every minute of "not a frame off". I will be using this thread as inspiration for when I have to tackle the body work on my 44.
