Registry 80 Series Registry (5 Viewers)
Just picked up a 1995 FZJ80 with 93,300 miles.
It has no mods. The last owner had it since 1996 for his wife and brought it to Florida when they retired 20 years ago.
My immediate plans are mostly mechanical. Fluids, hoses, and leaks.
Fluids:
My coolant is new but orange so I will be flushing that and replacing with the correct red. The power steering fluid is not dexron III and will get changed. The transmission, brake fluid, diff, and transfer case needs new fluid. I'd like to run with distilled water and a bottle of toyota coolant flush to really clean things out for a bit of time.
Hoses:
Although the upper radiator hose and a few heater hoses were changed, everything else is hard or looks really rough. I will change these after the flush. I am going to put in an OEM radiator, thermostat, and replace the overflow bottle while it is all full of water.
Leaks:
I have sludge built up under the transmission. Nothing fresh or thin enough to determine it is red. Not sure what is leaking there yet. There is also some fresh oil on some component near the oil filter. Honestly, things are pretty grimy underneath but rust does not seem to be a problem right now. I really hate to change a bunch of hoses and then ruin them with leaking fluids.
Nothing actually leaked on the driveway before/after the test drive and the car was cold when I arrived early that morning. I am going to run some UV dye in the oil and do a coolant pressure test. I guess you can do UV dye in the transmission too but I am not sure.
So, I have got to figure out how to avoid attempting to do everything all at once just because the radiator is getting pulled. I know I want to tear it all apart but it's not necessary and will cause the truck to be down for too long. The plan is to not going beyond 2 weekends of down time.
And the battery has some red stains on it. Not sure what that is since the power steering fluid is not red. The trans dip stick seems secure. Maybe there's battery cleaner that was sprayed on but I've never seen anything that leaves a stain.
That's my story for now.
Bill
Some of these pictures are after a quick wipe down.
Welcome to mud :flipoff2: :flipoff2: the official salute. Now get your wallet ready ;)
Cheers
1. Year and model
1993 Toyota Land Cruiser FJ80
2. Name of owner
Katelyn Hillmeyer
3. Name of rig
Nightshade
4. Mileage
287,000
5. Mods.
Gamiviti roof rack
2.5" Old Man Emu lift
37" Toyo A/T III tires
Official Trail Gear front bumper and sliders
17" Toyota Matte Black Rims
1.5 gal Puma Compressor
K&N Filters
IronMan 4x4 air force snorkel
Genssi light bars, ditch lights and rock lights
Govee Interior party lights
Plano Storage Cases
Raptor Liner exterior paint
Yeti mounted bottle opener
Lexxen window tints
6. How the truck is used
Off road adventures and my work as an archaeologist in the southwest for extending camping and overland trips
7. Photo.
The initial fill is not dexron III, that's just for topping off. It's good to change it of course, but multiple original owners and techs have reported that the initial fill on these trucks is hydraulic oil (aka power steering fluid). So really it just means that it hasn't been changed before, or that he actually looked at the fluid and saw that it was PS fluid and not ATFIII and stuck with it.
The red grease is for battery terminals to prevent corrosion/acid crystals growing on it. You can get it at the parts store in little packets, the stuff worked wonders for my parent's RV battery so we use it on everything now.
Ah, did not know that on the PS fluid. I never understood what was so special about Toyota PS pumps that warranted using ATF.
Good to know about the anti-corrosion grease. Sure beats breaking out the baking soda and brush.
Thanks
  • Tarik
  • 1995 FZJ80
  • Name: To be Determined
  • ~140k
  • Suspension Lift, maybe others
  • Needs a whole new front end which I am currently working on sourcing
Project rebuild. Meticulously taken care of, single family owned. I think it was passed along, modded and then wrecked. The chassis looks so good, I cannot tell if it was recently painted/coated or if the truck had just been so well maintained.
This is my foray into Land Cruisers which has been a lifelong dream.
1. Year/ Model: '94 FZJ80 3x factory locked
2. Owner: Dustin
3. Name of Rig: Maude (original owner was Bea Arthur.... if only it was Chuck Norris, Nicholas Cage, Bruce Willis, etc)
4. Mileage: ~ 130k
5. Mods: 2.5 OME, 33s , ARB front, 4x4labs rear, sweet ass Amazon baja style seat covers
6. How the truck is used: DD in Summit County Colorado, to get me to the mountain in the winter and up the trails in summer
7. Photo: Moab
1. 1996 FZJ80
2. Marcus
3. Wolfie
4. 224600 when bought last year, 226400K now
5. Dobinson Coils( progressive rate stock height), OME steering damper, HIR bulbs, lots of newthings -history and all work tracked in here
6. Carrying me to and around mountains in Montana
7. Photos -
1. Year and model
95 Fzj 80
2. Name of owner
Randy Holmes
3. Name of rig
Audrey 2 ( little shop of horrors fans will get it )
4. Mileage
215 on body 75k on drive line and axles
5. Mods.
3.5 ome lift
35 inch maxxis rzrs
nitro 488 gears and chrome mo axles frt and rear
triple locked
part time kit.
massive stereo
reclining rear seats.
custom grill
NWTI bunmpers ( which suck )
White knuckle sliders
Engine .030 over ported head and exhaust modified injectors borla cats and exhaust
plus alot more
I only drive it to the mall on Sundays!!! ( the long way around )
7. Photo.
1. 95 FZJ80
2. Zach Long
3. Ms. Maddi
4. 247K
5. 2" Lift, Ironman Bumper & winch, dual batteries w/ front & rear fuse blocks, Pin #7 w/ Diff switch, Huracan tailgate storage, custom rear shelf w/ "drawers", front & rear lights, painted every piece of 90's gold flat black.
6. Daily Driver & Family Adventure Rig.
1997 FZJ80 Collector’s Edition Triple Locked
Bryan Hood
MK80
247,000
17” Methods wrapped in 37” KM3s. 5” OME BP-51s, CO front bumper, 4X4Labs rear bumper, 3.1:1 low tcase gears, and 5.29s and 10% overdrive planned soon.
Rock Crawler, sometimes DD.
Stoked to join the clan! Just picked this up
1. Year and model
1995 Land Cruiser
2. Name of owner
Nick
3. Name of rig
Vibe Wagon
4. Mileage
Just rolled over 200K
5. Mods...if any
I think this is the full list…
Falken Wildpeak AT3/W All-Terrain Tires, 315/70/17 (35s)
Front & Rear Axles rebuilt at Mudrak Performance in Sonoma CA.
4.88 gears
ARB Air Lockers Front & Rear, powered by an ARB single compressor & wired to the factory locker switch
Old Man Emu 2.5” Lift w/ OME Steering Stabilizer and 4 Degree Bushings in front control arms
ARB Deluxe Bull Bar with PIAA auxiliary lights
Slee Step Sliders
Slee Rear Bumper w/ Ladder & Tire Carrier
Slee Rear Bumper 2” Receiver
Bowfin Cruisers roof rack
ARB Locking Drawers
Whiteline Heavy Duty Rear Sway Bar
Land Cruiser Phil Heavy Duty Rear Sway Bar End Links
Slee Upgraded Headlight Harness
Viper Alarm With 1 Mile Radius and Remote Start
DeltaVS Rear Panhard Lift Bracket
ScanGaUGA II
My daily!
7. Photo.
1. Year and model
1995 Land Cruiser
2. Name of owner
Nick
3. Name of rig
Vibe Wagon
4. Mileage
5. Mods...if any
4.88 gears
Slee Step Sliders
ARB Locking Drawers
ScanGaUGA II
My daily!
7. Photo.
View attachment 2781161View attachment 2781162
AND ... you got a Bowfin Rack with it???? Best out there. awesome looking truck! Congrats.
I’ve heard great things about their stuff. It is excellent so far, and a lot of the t-nuts from my Prinsu I have on my taco work with it which is awesome.
Side note question for other folks out there, should I be worried about cooling? It has a new radiator but I have read some stuff out there regarding putting a bigger/more powerful fan and fan clutch in to help cool down this hot, tight engine bay. Any tips? Just want the piece of mind…
On the Bowfin, I've talked with Pat the owner of the company several times and he's sent me new items to Beta test on the rack. I've met him in person several times also at Solid Axle Summit in Ouray, CO. Just saw him a month ago first week of August. Awesome guy. On the motor, I've never understood how a truck with such low compression could run so hot. I've seen lots of vented hoods. Some people also put a supplemental fan in front of the radiator. just do a thread search on 80 series engine cooling.
Just picked ours up. It's my wife's dream car, which I'd have never guessed. Her daily is a Tesla model 3, so she's a complicated woman and that's just the way I like her.
1. Year and model
1997 Land Cruiser
2. Name of owner
Dan and Caroline, but really Caroline
3. Name of rig
Too soon to tell
4. Mileage
233k
5. Mods...if any
None that I can tell....yet. Still trying to figure out what we've got. Double Din Apple CarPlay radio w/ backup camera and cupholders coming soon.
1. Year and model
1997 Land Cruiser
2. Name of owner
3. Name of rig
Too soon to tell
4. Mileage
233k
5. Mods...if any
Twin! Nice rig and hello from a fellow Bay Area 80!
Finally managed to get my 80, Aug 2021 in South Africa. Bought the vehicle blind as I was not in South Africa at the time, but the price was good. Absolutely loving every moment and spent crazy hours on the 80.
1. Year and model
1995 HDJ81_1HDT VX European import
2. Name of owner
Andre Hoffmann
3. Name of rig
Cherry (kids choose the name, no way to change it now)
4. Mileage
375 000km or 233 000miles
5. Mods.
2.5 OME lift with OME shocks
Intercooler
MadMan monitoring system
Additional boost, temp and pressure gauges
Caster washer mod
ARB front bumper and Warn winch
Badger Snorkel
Mods to come:
List to long, like most want everything
Daily if I'm home and building up to a tourer/toy
7. Photo.
  • Back
