I decided to go with the Toyota Tcase fluid since it is only $32 a liter on Amazon. I crossed 60K miles so I will do the Tcase
I did the Tranny at 50K since I tow a lot
The Diffs have Mobil 1 Synth from when I put the Lockers in at 26K. Figured those would be good until about 90K. Any reason to change these earlier?
What I can't find is a specific recommendation on Brake and Power steering fluids. Some manufacturers recommend 20K (ridiculous), some 45K Toyota just says to inspect.
Debating on doing the Brake and Power steering flush.
I noticed a recommendation to change spark plugs earlier than 60K, thought in these newer engines 100K was the right time
I think you’re right on with your schedule, plugs I’d do them do at 100,000 -120,000 and brake fluid depends on where you live if you’re living in Vegas and it’s real dry it’s not gonna pick up the moisture so you can probably go longer minimum where I live in Florida you do it every 30,000 miles or two years, very humid.
