I searched on Amazon for 08885-02506 Toyota oil. 32.50 per can, two can box plus shipping
That's the 75W-85 Differential oil, NOT the 75W Transfer Case oil ...
I just flashed on that thought prior to re-opening this thread. I'm thankful Amazon will take it back.Yes, you are correct. I picked the wrong amazon order detail. It was $56/qt on amazon. I'll go back to lurking rather than posting...
Next is a search for Ravenol 75W.
Personally I never do business with Amazon that’s just me I support local merchantsI just flashed on that thought prior to re-opening this thread. I'm thankful Amazon will take it back.
For those that are more comfortable with Toyota's recommendation, Redline now has a 75W MTF available.
Right here... MT-LV 70W/75W
Ravenol states the 75W oil meets both Toyota specs.
Well ... not exactly.
Redline states that oil is equivalent to Toyota/Scion Manual Transmission Oil LV / Part# 08885-81001
The oil Toyota recommends for the LC200 Transfer case is Transfer Gear Oil LF 75W - Part# 08885-81080
If it really is equivalent as you state, why would Toyota carry two different Part#'s with different specs?
I would not use that Redline stuff in my transfer case, but YMMV.
HTH
Steve
Early information about LF Fluid indicated it may use a high quality synthetic ester base. Possibly, early samples included some in the brew. Several subsequent tests show it to be a hydrocracked group III. The latter info aligns with the Toyota/SAE Paper on the development of low viscosity transmission and gear box lubricants for improved mileage.
Redline's site says "Suitable replacement for: Toyota/Lexus transfer case fluid "Genuine Gear Oil LF 75W“ 08885-81080". Anyone seen an analysis on it?Well ... not exactly.
HTH
