- Joined
- Apr 21, 2005
- Threads
- 116
- Messages
- 26,230
I had made some area on the trans cover to put a 60 series e brake handle.
Guessing the only difference between BJ and FJ axles is the routing of the hydraulic brake lines. BJ would come down the left frame rail because exhaust is on the right side. Would just change the brake line routing to the right side. Hand brake on handle on the transmission hump can run OEM hand brake cable. Hand brake drum on the transfer case shortens the rear driveshaft and requires more clearance at the back for the drum. I imagine you were already close to the torque tube behind the transfer case?
Have you found a source for the late model heater duct that's made for factory A/C? There are similar looking aftermarket evaporator units but the OEM heater is much harder to find.
