- Thread starter
- #121
Been dragging my knuckles, should be back at it shortly.
. I had to make a temporary out of plywood. Good luck and have fun!I am fortunate that I don't have those critters running around. The weasel sounds interesting tho.I am so jealous about your shop, in mine you have to constantly move parts out of the way to work, not heated and full of holes for mosquitoes,
black flies, horse flies, red squirrels and weasels to visit.
I just put in a temporary rear sill using 2" x 2" square tubing. First of all I should have used 2 1/2" x 2 1/2", it was really a pita to install but a good way to find all the other tub problems; if I restored the steel tub with new panels and time welding, it will cost more than getting a Aqualu 3/4 aluminum tub. The other problem that I didn't think about was after the sill was replaced the tailgate would not fit because the top of the rear quarters had spread apart. I had to make a temporary out of plywood. Good luck and have fun!
Generally when working with lighter weight material a 110 V welder with shielding gas is excellent. I don't know how much experience you have working with sheet metal, but being in a hurry is a recipe for disaster. Take your time. Clean/sand everything, outside and inside(if you can). Get the corresponding thickness of metal and tack away, make sure you have a nice gap (around a pencil lead thickness) between the patch and the body. Let the weld bond the 2 together. Take your time. I like to use copper backing behind each of my welds (see picture below, its on amazon). Did I mention to take your time ? If you tack weld on each side of the patch, hammer it out and lightly sand/even the welds out, not to aggressive! Leave the body and patch metal alone. When you can comfortably touch the area with your hand you are ready to weld again. Repeat this cycle until done. There is a lot of info and more experienced people out there, but this worked for me.I don't have 220vac available, I was wondering how well a Hobart or Lincoln 140 mig with gas works on cruiser bodies.
Another tip...when you buy your patch material, buy enough to practice on. Cut a piece out and weld it back in. If you use a thin cutoff disc that will give you a perfect fitting patch to weld in.I don't have 220vac available, I was wondering how well a Hobart or Lincoln 140 mig with gas works on cruiser bodies.
That jig is great , its very easy to move around. If you have access to the backside, keeping the welds knocked down allows the copper backing jig to work better. And its also excellent when patching holes. But what is really going to help you is practicing before committing to the real thing. Maybe a buddy has a smashed up fender etc.experience? none, but I've got to learn this year. I think it's a pre-requisite in owning a cruiser. Tired of using fasteners all the time.
I've seen the use of copper to reduce blowouts and it would be a good idea for me as well as taking my time. stitch welding.
I sell used parts, I've got plenty of items to practice on!!
Thanks for your help.
