We're completely going through a 1966 FJ40 in the hopes of selling it to a happy cruiser enthusiast when we're finished. This thread is for sharing all the trials and tribulations we encounter on the way.
Some cool things about this Cruiser:
We decided to take the body down to bare metal because there were so many layers of old paint already, and because of the amount of body work that we wanted to do. We thought we could use the 40-lb sandblaster we bought at Harbor Freight to make quick work of it, but that thing was useless.
The ball valves in that thing were all eaten away by the sand (we were using quartz silica as a blasting medium) within a few minutes. After replacing the ball valves with better quality ones and buying a dead-man valve for the nozzle, things went a little better but we were still plagued by clogs and inconsistency. Then the water separator on the inlet to the tank exploded. Finally we adapted the tank to work with our siphon gun: by hooking up the siphon gun's sand hose to the bottom of the tank and using a regulator to keep the tank pressure down to between 5 and 10 psi we were able to drastically improve the performance of the siphon gun, and no longer had problems with clogs. But the gun's swath was only about 1/4 inch wide, so that was pretty slow going. Finally we gave up and took the body and all its pieces to a professional sandblaster. We haven't yet gotten them back.
While we wait to get the tub and body parts back from the sandblaster, we've shifted gears and we're working on the seats. They were pretty rough, so we're putting in new foam and sewing up new upholstery out of a really high-quality naugahide that we got from our local upholstery shop.
As we make some progress, I'll continue to post updates and photos to this thread , so stay tuned - the interesting, mechanical bit is coming up once we're done with body work.
- Engine upgrade to 2F (originally had 1F)
- Replace 3-speed column shift with 4-speed floor shift (keep original transfer case)
- Factory PTO winch
- Full-floating Warn rear axles and locking hubs
