$50 Bounty: Front end clanking post lift
You should loosen all links in the air when putting on your new springs, then when truck is on the ground tighten back up to spec so your bushings ride in the right new spot
Dan, I'll throw in some money for a 3/4" breaker bar so we can go to town on those bolts.
One easy thing to try is to remove your front sway bar and test. Repeat with the rear swaybar. It is cheap and can rule those out.
Didn't I suggest this a couple pages ago?
Damn dude, I'm fat, not invisible.
Landtank caster plates will fix the elongated holes. If you go that route I have a set I'm not using
Are they different to other caster plates?
Any caster plate I've had anything to do with still relies on bolts passing through the standard bolt holes on the diff housing for alignment. Elongated holes could still be a problem.
Welding caster plates in might be a half decent fix though?
Just a shot in the dark from an issue I had a decade ago but it's easy won't cost you anything...carefully check the sway bar bracket weld where it attaches to the top of the axle housing. Mine looked fine when at rest as the broken weld pieces would perfectly nest together. Whenever the suspension was unevenly loaded the two pieces would separate and eventually clang back together. I must of looked at it a dozen times before spotting the fine crack in the weld.
:rofl:
I'm sure you did, but I can't remember. I can't even remember my kid's names or what I'd had for breakfast, there's no way I can keep track here.
If it ends up being the swaybars how are we going to split the reward?
:grinpimp:
Shot in the dark but is the front axle centered after the lift. If you still have the stock panhard the axle could be more to one side. If so the front bump stop inside the front coil spring could be hitting it. The bump stops have a metal washer in them that sticks out and can pluck the spring like a guitar pick. Some people just grid it down but I would buy a adjustable front panhard bar. Hope that helps.
Well I challenge all the Mud universe to figure this out. I'll send a gift certificate worth $50 (or just PayPal) to the person who can correctly diagnose this issue! I have posted a video below with audio of the noise.
I was on a trip this past weekend at Bald Mountain OHV near Shaver Lake. Super fun! Probably the hardest wheeling I have done to date in the LX. I removed the sway bar completely prior to hitting the trail. Suspension still clanked like crazy. There was a guy there who was a cruiser mechanic. He road on my bumper as I recreated the issue and couldn't figure it out. Neither could anyone else. We also ran a bunch of trails with @gwnugget who also owns an LX450 and has the exact same noise in his front suspension. Everyone thought it sounded like the springs hitting the spring basket.
Same clunk I have. Its not my sway bar because it happens to me when its fully disconnected. I figure its the spring hitting the bumpstop or slightly twisting in the mounts. I will be excited to hear what you find, its disconcerting.
I'm baffled. What I'm baffled by is that you all have rigs that are quiet enough to hear stuff like this. Between the failing door seals, failing moon roof seal, INTI rack, lights, knobby tires, and ticking of my motor I can't even hear myself think let alone a notice from underneath my truck. :rofl:
:rofl:
:grinpimp:
Definitely not the swayer unfortunately. Been running around without it all week. Clank still present
:rofl:
:grinpimp:
We'll have to meet between Tucson and Phoenix for libations or something, I guess. :p
Did you try the rear swaybar? When mine would make the exact same noise it frequently sounded like the front.
Track down my clank to a loosened front control arm bolt while on 4XOverland run in Utah. Stop and tighten the bolt and keep on traveling, couple days later i discovered the damage that loose bolt caused.
Control arm caster bushings had shifted putting stress on axle bracket.
Replaced with slee caster plates.
