4.88 + the ect button and the balls to run the rpm's closer to the top of the power curve works. If you really really want to make a difference, drop a V8 in it.
Cheers!Here's some food for thought for you guys...
A friend has a '96 with a 4" lift, 35's and 5.29's. I have a 2"ish lift, 33's and stock gears. We both filled up at the same station, hit the road and stopped about 70 miles later to fill up again before we headed off into the dirt. He used a little over two gallons less than me. TWO GALLONS... over 70 miles. I can't recall what the total fill up quantity was, though. You would think that the extra drag from the larger tires and taller lift would have it the other way around. I suspect that even though he's turning a couple hundred more RPM than me, he's doing so at a lower throttle opening as a result of less load on the engine due to the gears.
With winter here, we're not wheeling as much as we usually do in the summer, but plan on exploring this phenomenon more carefully when we get back into it. When we get some hard numbers, I'll post back.
combinations:
If 0-60 mph and fuel economy are things you lose sleep over, I suggest selling your 80 and saving yourself a lot of pain and suffering.Getting down to pulling my 3rds for my axle maintenance and upgrades. Been thinking about R & P ratios and all that, againand an engine speed calculator that someone in another thread suggested came to mind. For the 4.5L FZJ engine, USA spec, 65 MPH with 4.10 axle and .77 tranny ratio in our auto overdrive (4th) and other reasonable
combinations:
Axle:1-------------Tire diameter"--------MPH----------RPM
______________________________________________________
4.10 (stock)----------31 (stock)--------65-----------2224 (stock)
4.10 (stock)----------33----------------65-----------2089
4.10 (stock)----------35----------------65-----------1970
4.10 (stock)----------37----------------65-----------1863
4.56------------------33----------------65-----------2324 4.56------------------35----------------65-----------2191
4.56------------------37----------------65-----------2073
4.88------------------33----------------65-----------2487
4.88------------------35----------------65-----------2345
4.88------------------37----------------65-----------2218
5.29------------------33----------------65-----------2696
5.29------------------35----------------65-----------2542
5.29------------------37----------------65-----------2404
One would think that matching stock RPM would be the goal. But, if you think about it, that's only if you're changing the tire size and you want stock performance. But if you're adding mods that add weight you're going to have a performance loss due to the added weight. Just like when you have a full load of passengers and gear - it doesn't seem to have the pep that it has empty.
So does matching the engine's stock RPM at a given traveling speed help regain stock MPG, performance, both or neither when doing mods? I'm thinking that adding weight is always going to make MPG suffer. Regaining stock performance may be possible, but you'll still sacrifice MPG. Engine swap to a more efficient engine is the only way out of this![]()
Nah, I like my pain & sufferingIf 0-60 mph and fuel economy are things you lose sleep over, I suggest selling your 80 and saving yourself a lot of pain and suffering.
The only diff ratio worth it is 5.29. We figured that out, what, 10 years ago?
