red66toy
Supporting Vendor
Hello all.
As a long time fellow 3FE owner, I have spent a TON of time going over this engine to make it run its best. There are not many sensors to make it happy, but refreshing the system still takes a while, especially when you have to hunt down not only the sensors, but also the connectors or terminals or seals!
So I thought I would share the fruits of my homework. This is a simple post for some easy and pure tech. Hopefully it will save some of you time and money to get your 3FE up and running well.
You can get these parts from a mix of places (of course stick with OEM for sensors when you can). I won't list store options as that is not the point of this thread. An easy google search or mud members/ dealer are your friend (please don't make this a sales thread).
Sensors:
EFI temp sensor: 89422-20010 (89-92) . If you have an early 88, it's worth it to just swap to the newer one as the early 1988 one is NLA.
Gauge temp sensor: 83420-20020
Cold start injector sensor: 89462-20040 ,
BSVS: 25820-13020 ,
Fuel pressure sensor (NLA): 89428-14070. OEM work around: 89428-28030
O2 sensor: 89465-69015 , Denso: 234-4056
Throttle position sensor: 89452-20050 (88-89 FJ62) , 89452-14050 (89-92 FJ62/FJ80)
Air Flow Meter: 22250-61010 (88-92).
Idle Air Control Valve: 22270-61010
Connectors:
Fuel pressure sensor connector: 90980-10197 ,
Fuel pressure terminal: Yazaki PA series PA-SKT2
Fuel pressure connector seal: Sumitomo DS-250 single wire seal
Cold start injector sensor connector: 90980-11061
EFI temp sensor connector: 90980-11062
Gauge temp sensor connector: common female spade terminal
O2 sensor connector: Anyone know this?
Throttle position sensor connector: 90980-10378 a copy of the Bosch Jetronic throttle position sensor connector
Air Flow Meter connector: 90980-10071
Air Flow Meter Terminals: 82998-12130
Air Flow Meter boot: Look up "Bosch Air flow meter boot" on google and lots of generic options will show up.
Idle Air Control Valve: 90980–11144. Available new or aftermarket for cheap
Tools:
For wiring repairs I recommend the small investment in good crimpers. These have been fantastic and only like $30 :
Amazon product ASIN B0050KDKUC
Sensors:
BSVS: 25820-13020 ,
Connectors:
Tools:
