So I pulled the old and installed the rebuilt injectors on monday evening.
All looked OK except for #3, where I apparently forgot to remove the old large brass seat and installed the new seat over top when I did them over 2 years ago. Beginners.....ha. Diesel Knock anyone? I took a step back and went "Im an IDIOT!"
the base gasket was not present and must have gotten burned up and blown out the exhaust.. So I found the source of my hard starting, and loud diesel knock. It always started with a lot of white smoke ever since I swapped the injectors and had a audible knocking on one cylinder.
Ill post pics of my nube stupidity tommorow....
Anyway, one at a time, the injectors were removed, and the crud carefully scraped away and sucked out with a nifty rig on the wifes vacuum cleaner.
I used genuine toyota brass base gaskets, brass seats and new leakage pipe seals for the install.
Bled it up and went for a drive.
First impressions with the new nozzles and pop pressure at 2100psi:
-Sure is quiet. really smooth idle. Like REALLY smooth. almost sounds a tad retarded.
-I didnt touch the timing , fuel or anything else, and power seems just a touch less. Im pretty sure the pump needs a slight bit of advance to take advantage of the higher pop and bring the power back +some. do that tommorow.
-Starting is most excellent. I didnt use the glow plugs this morning, 3 cranks and running smooth with a little black puff. same thing when I left work at 5pm, but started first crank.
-Runs SMOOTH throughout the rev range. Doesnt sound like it going to come apart above 2900, and the power consistent whereas before it would almost cut back at 2800 and run out of puff. Probably because of that #3 injector.
-No more boost surging at part throttle loaded up. again, was probably from #3 giving an imbalance. So those of you having the part throttle boost surging issue, It's probably due to a large compression difference between 2 or more cylinders.
-EGT's are down about 150-200F in certain conditions, flat ground and slight inclines at highway speed especially. I expect this to improve even more with the timing advanced.
Given the #3 injector was causing a few issues, I can say some of the above would be normal results for any injector rebuild, MONARK nozzles or stock. A lot of VW guys say they do notice a quieter idle, more zip, lower EGT, and less smoke with monark or Bosio compared directly with a stock rebuild side by side.
I did notice the base gaskets dont have a lot of crush in them. Compared with a new one at ~1.07mm-1.15mm(they are supposed to be 1.35mm), the old ones were crushed down to .89-.95mm. I didnt think that was very much.
I might swap them out for a set of Chev 6.5 gaskets as they are a true 1.35mm in height. I measured them today, we have a bunch in stock. Same OD, smaller ID by a mm or so, and they look like a more robust contruction.
cheers
