34s vs 35s on the 200 (5 Viewers)
Denver, CO
I recently went through this journey in my build thread, but I figured it might be easier to locate in the future on its own as more members buy and build trucks and try to determine which size tire is appropriate. I think it's safe to say just about everyone wants to go bigger when they get new tires, and the good news is it's easy to go up a single sidewall size with no issues. *In order to keep the measurements specific, I'm using the published numbers for a Nitto Ridge Grappler LT load range E for all sizes* The stock replacement LT285/60/18 measures 31.69"x11.5", and one size up LT285/65/18 fits great on a stock truck and measures 32.56"x11.5" which nets you almost a half inch of ground clearance and looks more proportional to the 200. I have not read any issues with this fitment, and I think for most people this is a great option especially if you're not doing a full build.
For those who want to go bigger and keep an 18" wheel, there is a great size in a few tires that is another step up - LT285/70/18 which measures 33.98"x11.50" and that increases ground clearance by over an inch (1.15") from stock. In my experience, the gains from this jump are pretty significant, and there is not a ton of work that needs to be done on the 16+ stock wheel and stock setup to get it to clear (16+ 18" wheels have slightly less offset than prior wheels - not sure if that would materially change the fitment). I had to remove the rear mud flaps on the front wheels and then trim the front portion of the front liners and bumper to keep it from scraping under articulation especially while stuffed and turning. IIRC there was some very slight rubbing on the KDSS, but it was totally manageable especially when just driving around on pavement. There were no issues at all on the rear tires fitting. I later added 0.75" BORA spacers which have eliminated the rubbing entirely and give the truck a nice subtle change to the stance.
While the 34s (285/70/18) fit and worked great, I have to admit I wanted more height out of the tire. It was a combination of desiring more performance, but at least equally if not more it was an aesthetic decision. As some of you may know, my buddy just lifted his LX570 and put 37s on it, so when I saw my truck next to his, my tires looked small. Even though I was perfectly happy with my 34s before, they now seemed inadequate, however it was only in appearance. The 34" Ridge Grapplers actually performed a bit better than the 37" Cooper AT3 XLT, but there could be a few other complicating factors I won't go into here.
The good news is the Ridge Grappler comes in another inch increment taller tire - the LT285/75/18 which measures 35.08"x11.50". I figured since the 34s in the same tire fit pretty well, the 35s would surely fit. I ordered them from Discount who price matched another retailer's sale that @JohnJB told me about, and they came in a couple days later.
After they were installed, the guy at Discount said they were clearing pretty well on 3 sides, but it wasn't working great on one. I knew immediately it was going to be the driver front tire interfering with the KDSS, and I figured with a little tweaking and maybe a new alignment I could get it working well on the 35s. This is one of those situations where if there is a strong will there is a way, but I quickly realized I didn't have the will. I tried 35s on a prior 200 once, and I had tried different wheels, KDSS relocation and an alignment but it still rubbed pretty bad on the KDSS. The relocation kit also puts a lot of strain on the bushings and didn't seem like a great idea in the long run, so it was out of the question this time. I also considered different offset wheels, full Tundra swap, and a few other ideas, but they all seemed like big money alternatives for incremental gains. All of the options also seemed to have compromises somewhere else - the KDSS relocation is hard on bushings, the Tundra swap requires CVs, UCAs, LCAs, tie rods, rear wheel spacers and then the track width is ~3" wider (good or bad depending on use), wheels with the right offset to clear the KDSS would likely contact the fender, etc.
I figured it would be smart to go around the truck and measure to see exactly what the gains would be with my own eyes rather than just trusting the published tire sizes and running the math. Turns it out it was exactly what you would expect and the overall clearance gains were 0.5", so the next step was figuring out if the half inch gain of clearance was worth the cost to make everything work right. On top of the cost of the 35s on the low end I figured it would be about another $1.2k to dial it with wheels and alignment, and on the high end it could be significantly more assuming I bought new/not takeoff Tundra parts.
I've had trucks on 35s and 37s in the past, and while there is no question the bigger tires make many obstacles easier as the tire just rolls over them with less drama, there are definitely downsides like the additional unsprung weight which makes all driving dynamics (acceleration, braking, handling) on the street worse, extra leverage on mechanical parts making breakage more likely, wider turning circle with the extra track width, and makes things like adding gears and lockers a next logical and $$$ step. Overall, I decided the jump to 35s wasn't worth it for my use, and I've gone everywhere I've wanted to on 34s so far going back a couple years (had nearly the same setup on my 2014 before the 2016). I love to see trucks on 35s and 37s, but for me and for most here, I don't think it's worth the trade offs and extra expense.
Here are some pics showing the visual differences and clearance difference between the 35s. Both sets are brand new (I was able to return the 35s for new 34s as I only put about 6 miles on the tires) and aired up to 37 psi on the same surface.
35s (285/75/18)
qs0FZuJg9uPp3plKteapEAVQ__aYJvZLX8mJUCrWvQaZjWh7FOobZFQEWtOaW3eMtScdqtWgVrgWxfJcxWBEqLNK0EXwVxlKIYzw70vz1eIAMZzJlYx37M8_5eJcyj7ZWXdfi5FraOfbWCAmrvq_obVE4fEn5m8c5EO0RWzILSlJoJsLDveyyfmVa-xLGwNhsKvDQxikhzKmoKuFGTgioWqJHcXGWsMCQLvLcvIjXfq2tDOfcz6_JnNjs_kQxVMKm6iRlPCgu9UyTArRAi6WYm-uvwfQPKLbvdEkmqoeW7UqZLzj4b14en6ucheW1G_NIrZJ4wVj9Mg1EVn4TkbWwj5bsHV3D9deYtscPaLMhvU0IsaiC56g7nrs39LylCZh5AtH8FrlHMJI8aIzNfMxSSgpCIx3R1sVT6WIw4OHw1BU0HYoxPzue8thEaTZWv19Z_-fhpmIraTOMIw4jjS_iSqnVEC3Gi4EDIIZi_6CyhurQRAtfH3uhfFH4mOYrFpwq0WRFsaCYd-CM3TZ6IQLFJsyYMwkbY9AHp0Elf_BkGPrd1wC9cXPnrN-1aGe8wg4yfridrK2z_oMy_VMZ372sd5zw4KofPleCg7HA2jb1s6Hmyc4E-L3g4ZSLWvJJndw0AgyKWEnlUKdFhv68pwqQdMCW613Pmxl7PSZdtltplYZR2hJTYQfcliHExtu29azByA5a2Bsc467V0kS_wbAcZU3hA=w1292-h970-no
34s (285/70/18)
APW4UmB5fRBTFX-C89f41Cd7-HJKNnzkmFoviUEnzP0UkSEu65_5AdI3mw1Ox7IeKjA90-zi0Noc2JO9Dgh3xGSYq5MFMpKJCB52mrM1iSsFMkB7BnCBtOe8FETU_vZzSPSP0QKyNU3GRD9jQ2crScR5xfuBJRMxqz4UExzadVkWQdXy08Pww3DoR5iIS_nTabQsEHWal4aQRsl2w9CPvBoGKNKVtdPE87d2KBLM6s4746GuqpnkeMgNdskUr4KGpDySgz0yZJMXXHZOaKz3jlh1e8tuI9IaCKIWEtYyisZ1CFUF54VdqCRbk6PtIQTTm8t3ZbrdzD7CIPojg565_El-eN6Uf68sMF-gGIJdz1AFw7JAniM9TSHUzR3Y31m2LtVa3f4YL_7jRUIL8PXrN5LFr_B-ZcyXvjFQB2ZI7qouq47EADs5ZPA4HyW2sQVjZxPeeHv9AnelH-bcF6CpOmQen-pEkqQ-7gyCa3h4UjPR7ouV1bK89VyJTSIPSisa9bCHg49ZAGp5dgG16NkcfCXP7ODYjyWD8nDL-u3ESwGnhAtn5cUKifCt3fe4zi5DByFRSXScbsIf1V4V6rMPPxvCy3cy2m60KhyY8b_qWEk6rhUoZs4ehh4R2LDO1pys649KIc89hmA9qX1VITX5QMH7MS4SfC4ZjaYnukXNCQkvlh0i8EcqhYYuwFczsh-nAaiIcYd2JPzbhGvPbqI4m4dbuQ=w1292-h970-no
35s
SA9BE3l1NkySwpDJmgEG_fPpzv511ZL42vQCSEODfDGtIJjXfHlrUNS-J_cusrJT56ZbYvV1VwxnH_3o9RlZg9YF_D8vnGKDpeG23StSIDkQ2wkK5AuLMJWOMWTfjz9ZKnkWU-HFh3xEhNsH5z5C6uZY5gQzVQt059kKIbuWJsKrFBPeGEzhkbStM4f64502ik6m_4uZPSnTQ2Fncsiya7apYSB2jCpY2L1LIcz5zOTregfaU8-Sf7Ye2RGwDkydO4nQWaL_XoZ0pUe3SvEpvmj5Ao6dENCL5pr4UR2X52y1vdmFhNtpXhUaNc-HE38EkH8G6_jvud8Yt47sRr1Y-YkqztSsG9ywQ4NRzzKL3hFXp1YuT7GFT4ajeZv6RRu6Hs9zFGnf0lLkPOT8PxedgwpNrbYOQB1OnEKy01MDWoEpUkgJsm7boTRhZsnE_2BzuomA8Qfwy0wTHHDo9_o70M6yevxrJADLdXofmyNWrHnT-vD_lWDXm3kluVhfGuwkN0kzEOEQA3xPT9_iGBv2ZnVtwen3rYMMOKzFCJQGHXx8aY835pvCvVRHkyvibAtL_tl1PtnlBNb-LQgbdZzUYf64WDeIMt28toMcslm57PgLg_T8EwEkwm28hkzvKnDNudzR41VPzCUusufsAifi1dmEgK53IA73M8sP_REo-CXuEDyQjT8bUQDE5YeVlyzsNpsWATiFQPtWyZ5abaBMZut2fA=w1292-h970-no
34s (this is the most obvious view where you can see the difference in size)
vr_-CB2nlMnNvJuaUpHLnspELcCZdCs-9tl3hHYkI0odDgobsS3gDsFpGGjwAgRhFtR6Qd3s8i3aLZzvm6IRkWNTG_-Vez2JVGl9fjDRdcME9j4NiklFEAY3jpiIJI0UgQmlhLqO70rWxpIkYWVmec40WvAZJvPIPOESxnlIKVEhxDIm3GLa8lCvLA0wVeTJ4gW0ZZ7zL5pFOFdzJ66EJkL_ECwAgV6nFGTfNNQBS59xEgF4pUmra0TQMQ7GR2BAXv6SArHwZINWrJcLI5DnUVEQYfHIZE1DZqSP_Bb6JyoH5HUhucmj_OzU02sPlwoiwjenLX4_XE1gwmMmZ9xWBKXU5hoW6KkoWCOp0Z1vGZU1Z4k8ZxImbYyCOXXTKarjK9PIxrT-YcBSLgEjdhOXAeHKMWWaA4cy-j0ZG5qWyUGn7K6Qe8he_BwVxt5WkHJQ9rB3_VAzPQ28y9Fr7JCBQ3HnZHHwabMpR4825VGfk0Vs6ozU4uL4MZ4cnxvWO9h4n2fEQGTTA8wd5_XSQ4u1wFzt4zs0Fe14Hd4NJuTVZ2x05d8KJ2BAS89q2jcoxJEw8zPe__wAAAwlCXzn0GIj80M_EZVG4DgunKzsuTVfNJv7Nn-0BrWDh8giXpZsSo2JXvh_e0xDwjumXt3rJ9uACyG9-EBinBFkfKbsCIJ2JDgqaToVToqtE8lG19eXjCv_6QLYhiHfOFwaSDYrtYA9WxL1BA=w1292-h970-no
35s garage clearance
nh_FL9TDHaX2BFOQXdm4ILxddCuFeusknwu4RNJ1Gz15XI_9NPP1H962vbXTGUiT8VzgsPBGCLIiQe-yJpWRtBWDb4f0lsxOLUUEri4PkV07CYHV6lXgs9lvaVYMjqzLV6_U6FM2vdf3uGcjooXHbVYs5JaSZEdnVZ8HBvPBK7v4_ivZGSt2EjBGhkfFnhoO-18kartp2JIKwF1AK71aQ-Pr5Uu3-OAOg35ULhq-5j7Urw_UlRy50j4EeTfxqWe8rWJZK10V2466C90n7JLWDJg3_4WUS-1NQGUlDgL4Jp8e7zbW8G5WSCKK8LNDEU9_cv63I4ubh3PvoV6GLTPBummBCXfSmHXIaqck2GUM26yMxk6m8EfsIAixPF5_RsMfcGtl9HbuJj2zki2P0ANsQA7OE7nfBqb1AW78Vf_OJ5AUAXI_nZx6sQMN8QCtgruxbuNPta24UAu3Ctv06kS8y73ACSypjn2wr0kwgYvGR4tpbrr3fSjNhDbgCh4Zgg20xS-wT1xJwEIkXqICqB-aE5WTY9wA3i9SRjeiGcQIwHXnQ4vDE3u_3kiwxMkm2yB2oHx7yOAWL393ebB799JP8mHiuCglFiK7q6dIvbLumIP1inbv2FQVdG1guG04U91eebgZ3Q9hwEdnkplhghJjAnNB3hiNYH5NSi7YItks7czkTCdaGUIpfHXwe5JIX9uaAgLd7GWtGa3kOEaK2kc5gRM3tw=w727-h969-no
34s garage clearance
ZVN00dbdCh54suVoeuAMxqfuuXIC2Bx-lcZLQvq6z_33QQu9pTUxPiPhZ3AHbpbXyJg-TbvQxjGG7azUWnOOqGE9H5fkxAHluaPEEU3-zJxYoCVa1w-Fi5nlaVWYOVkez0f2Ggbzi9gkha-Q5ebzANvz8QepFwQStY86HE3jBLXS6CpKpbhtbEJaXQBKk8jC5azZ2W3fgD888gFi3hg6Mi_1JHfwflWBmz13QYHf76BVxf5K0wEIvWy5aAUwKdHc404JtqjGrcFq-XPmi5dkzMsHfrBDvVKObLcmibUY6co4jodKtoid-gF2X54wFDWqKbPGAytrS2bnxZQUDuOYb7o5zp63iaIwzOWXM_iEoSghqrCQgdZFhop90oSK7fuZguUDFnUMM8WV-N_wb7C1BpULp8qWPWV1S9mlfx7dKx0RIT421GSzdHT9mTbQFpssu0nNfuLHks7LoGdst5u9RQC8pM07HZJaVKhe9R48nX7OcBc5HVMiNZwv2l18eqOHA37BDo2WVcizRxPESn4uz6-CjFXU6lufVQqswEkSbN2qdx7_CY2vY0aJmZNPlPDHXQtbQ4Cs3PVlExC0v6WjQ1gXQOBAE7hgdJpqBKpM0zcIs8TlU6yak0yUB5YnDPoB6FE_OkAyG-Y4PnTXT7XfsKmm9PhRuzvPHva8gBwFlLxZHm_xmgL858qSEHCkqYQZ1vxHFHYigd9F5nu49CrvdodArQ=w727-h969-no
35s
Gj2ZDfs_6DNv9v2SWA5alfb4hE7IteIJlXjzmOdJI7YRewBn2uJHMx7_vpHthnnROI_pvXfDt0GLj9bU7N4PGcCLfKwLZla7SQEa5BZzORQv6NdyBLNFiDdnC9ki4iA6uVSrJuBuByPNGnTdbZr494rpAvcpHo89M21_gHQK9e9q8DfjELgqIFv7Z1zlt09HISYSD6NHcdcfrq_AW8UKjGJ-Ey4dS-PymYVxphZ-DBtSF4o3xz8UyV7Gb9tSxLBj7UrmNxapjDzMKsJvvuQ4L1cpEmLoE3TYNJKgXbT9rQPM49SFYFbWDuFbOe30H2wXdppa-l6NzP646sICF1R-eO796aD7bY4-0z6MDhvuBIFA0d0O-jN7xy-YiweVEENZTOZN-0L5Y7iWTulnCiaukWN_oJ5EWkDlbXgVBzeLLzuXn8PpM1kCLzUIHQs9LKoAhI-s-yxPeUJCYZq1hRwudvrJcDPcRKSlHpWJrLK4qzDcDoPiws94Lswe5FnTaRWo35r8FtzfRQEpFaGslffQWAYob34qbl1Nbiy-GY3Uz98_4qEacF5pDTaWGW-1Yc6YxZ3TctfTAZb2v-LIXYZFnxeB-OKa5lvsHwoMiIAmf4LgWMKP3sz6ro0Yu019almr-DzWRFeQeZ7L3CqellF-OF14WJHEP-z8OSeVZVhd4aqeXofhB18hFPwydURhD_4Oai6SfgMBL0HatpvbDq21ZlHrYw=w727-h969-no
34s
F7CCCzLkV3IAtHTCTqIHqRLYIEpURNPfJ5vUfQ9Jgg9qX7dBHYrYlqtxTre9TBa0S9wnr_8HpRugjyskX983ixza0yAb1T4M_eLlnctcmMImpgjNSSrOmftBoCc0cPccHqljVZMH9oLEa0N__kkIl_Wxw5o_OwuGnM_PTyljzok9r738OzKLptIjFkQgfhDQAcX-AgMNPe_ZbkZA1NZCH53n69IAFWFUgDOHXt4Cmpp5TOOcpkJZzffagMW71RM2EWS46jxDyqgbHVwGcPcJGklw-ejd-jR05JXQqEiHg_fDwKUxl7QquZsUykhVbFLT4sZnSUmNV5RemhlDhasRo2mAqUbe9UNyjY36_-roFNdv3QGO5lusZ0tRGAcPuuBupRFlFH5vj0MqId3FVER09mekAs3rx_fPSkfi5NUri29aqz_TB5zoEOe45Wg4WdZuGwo1DE1HXnngiYLEwAO_igr5Pyxu_pN12YmBIPV8jlGSLJcXwTmW1sN3U_-fb7_rqQl75ZbYUic4P23LrAUpwaPqsP3MNzok2cVY58_AbFnywzab9a4t9qqHR-0XxGOSwyftgC1Gy6f1WI-MxBxYuyRIuVYebybAvDlNqWgOvDKldlZT00E5TFfepdL9-BKsIdbo8_q_VQYnYp8xbDWE0u1pHVo616b0R_H9pIxeB4Ex1txnWy9JVTxYeZiBIfzl7fktNODGTqNL58WDM12slMX4MA=w727-h969-no
35s
9Ge1241f6Iw-_qF7aWl9UaDl73jpgOxSNgt_ZhB5gc7xvPrFPyIaDDICRMwVJNayzK3HH_qvd-VuEJkEz1OpY5USU0DiHpSLY92_DuhIkhqmZnLdIw8delKbQZie4jIBWL_m8Dipap13aTX6lI0OQIBakbSj8hFINSCudOFZJ5IXAXau0B4ERNVfRDyiMw9nST7UY9sPq0THLSkLXdn8DZtmYrFwxYdL4nxbXnpM84s2-7JHATfTYv-iS5rZ60SCkBX6d8EQxo95R8mQuHhK2XkTNkSk6bPd6oYcKu6eVe5GyTpVdfqwpjqzdFinJCDaoLPodLoSkapJnWE5pTRdPm6FcRnIOablAYeCWanLGrRfSWwWFqkM2dguYS35XGBzMzNLIk7cbuPITRDqNlrZheAWP3-p7MRcBdMNVNORYp5ZKVq9dzEb5EsTHDqctMN_rtZuTKHDoYQf1Pz8Qo1XpvIcf6BSkgrIGPOVMXV5RiHjDNkx94lx_CwZ1xMSKqPeJjkRfWVBkpvMhaWk0tJnc1gnbCrYPHFLwADfUCLjrQLtfjPI_VMj--URWsbxtvL7Z8deY-XaY962R_ArXsKxLI18chfeUbVJCRsfkJEPqanQ0dAkC-y2ZKju5UIB9pTuflqNlGuw3wlorZtj0xAYWVJxJCmWOJz3mPcM2uM6DZshI8P4kiv422jqM1Kz0b27JAIMdrTutxO8jUvcu_snHAeTzw=w727-h969-no
34s
HOjszBOWM5a6lxJ3EmRKXZkDjOZg433TWyXlhb59D3Ea1XNRubLO8Ho4rewzu4QDdWZzxRQF34-F21BonqWGC9_v1PBeghEgR3giV8Nxv-Zv6ptF36Ul38D9Zq2LKBtq6bl5gCqQ-YkQQ6wceRmsePX9D9-SIMFVDBzRZPfD6Kwt_kiF9RRw953P1KsA9ghhCD_lZmWR4DiWyr8wXEveYd8YAO0r16FOqee4MUWtCPjnqfNX_8eBU6g4xSVhG_hW7-Q1KhKE9H2CrIEk9FFBSoFxqNaI1yqOIa-Z_Wp4WaH93TY2LVzJwrHS9Jw94dnRll3LJYVETYcCcMws3CqDZPz6z2b02ntt7qJMLZXWxji-fM_hu53GO4BMq828xJOVTXpM6JpdRf9Ocvqer7jA5SA4pR2rs1EKTDdR6eJKXNQAPXcad590xGrq4cGirkA7SLt1WYcvLZ3N4Cg8lQhpEdKV4CyJkHT6vJNrRBPaAQbJER7PmvhyAnlRosMj8cBhhRbryQEhNqm5v70KokT0zUbuq3q8rCg9WVCzdqaJ3l1E6Ut29_SJU8M7qt9-xU3Pr8Wi-HeNTTO080p9mUVAf2PgRZQWq4eMGcqOTzc4ldxdyvpm4KeA7IqZG_D3I1N7EVugvP-QfHsCigi3QSf6acV6PuoGwkNQLF5xG21pAJMejKKt63n_vE31wf9wXlk7ZhkFW8pM_h1jaTqTTXHzlj5RIA=w727-h969-no
35s
LuUbKxUQHD6-51Vh3Bj2rkLwcOJ78jUsfiBHbjXr33SzBlT438WTQFIgp2c0dec53s3svQJQd0o9zOtJiIiTstmuj50SK8va5gkb3xzetkJIzBjqOmjisexSWtHvSGHYhsJ63fa00mfSVDFxu2u_3bmMyXFJpEYCBn2_-SxTE2X0B9umYrZuNpM7n0kQu_aNCYB0OhedCHKo32EQDH1W3eX7qtejXtw017e_PUhsmFrxinl4Jm_rUPdMavScRV31pr_8BYwxKU2n8q0Xgx-LVrWOyYwJ4D0gCrBRPkK4GWXgbwEF-h-MZnTiOBZEU-xw7FoQuMXssc1M73wnIUgsTSsg-C8_mkDv-v9sPAzb2bevZo5EJTi7SHSWC-Yac0Ws_9PAiyZuWX1sdvb-JwhWDtu15CpSLwiUKeBCPktwu9WDwhdGMDLvrto9xHpFeh2w1HovfsxH2j1DJJc911ND0Sa3M5YTmemKSJD6IdobwaYCLCbnGupvbCAhlZ3NCY8wsINzoR37Q-Wh3euaY3X9otiszIjJdF5Yz8_xeYWLUY7dnTMrjg-b3Oh7MLbkGQTOoXnHrzh7ZouNifCzSrjfvj0xKeX_YKtWVSw3VUVjjvVrpDb2WECeJu8wIutuRZvBLI7v3-wbdxHlDwBVX4Oqy3bAhd5uTwoE7bSLYOldXJiy9A29ad0YfUtENhUJV7FHxnlmaCT812aso5zJRN1VgR9ehQ=w727-h969-no
34s
XM5ljdZx6OyXVXGwFsHBzQND6reRexhbfltObB5iAfl68XQjfP2gW07oyFhLz5SBQ6rcW2m5CG2RV6OI5UZKYN4jNqkiLinubp2QZguc1UbREFhQrgoXM-yh5mY50ngVNN8Rv6syWYROzOuOZRCXx3NIZYW86LQHZNLkOafh8ZZQfesS_sMQamoMUqdKkgGjK2C2m8HdT_bExl0n-r5foxEolHOhr6LprVjU0_5rWzDfxSmcSyRxm6NftU6TOGFHgmIE8VVAl_KhpwXy0HkE4FnCGFjMXwr4q98M6MdoIhg0vyeyFg6nRlhy-DtndreU0bSMDdx7dYcvE1I6KoSenhOXQw997OkLTEfLjOh42X6wy58Th3Gp4ra_BWp2oTdr7W-rE2OHOC55GrZrk8kVkzlGTOMVjzJlp3Rs5BBxrPKKp23W0DArE-uQv-1EjYnpPFK4qV4ACswZa_8TGurgJcUfEuvkmH4SvQSN-4SY8IoMVST3CUv-dC7Y9OX1aL1ASEuuWxd5qoj90KxJOu8YahysTUahsEJOdxxeUM_LphrhBHKY-ijs-kBftMAilxQrwb_jgA1VLLN8UtPLCoaO57lQ9MllMgjiZ_Mi1WTs_80QU-fFHp0zgT8doo-_Ns_6Ck-8BFIn15fhUHRC3pR5CnvVM0xWgJ_8w8grk6RecYqrWrzmyrcEXY1KQ_cgw-wAbvLPpjEalxWUXtGtZeHeiovKBA=w727-h969-no
Here are a couple of pics showing the difference in KDSS clearance between the two tires.
The rubbing on the sway bar with 35s disallowed the wheel to turn to full lock, and 1.25 turns to the right the rubbing would literally bring the truck to a halt.
mF4xjZsOV2ojM1WjlqulLmA7Rp6FrGRfQH97-_Z4t7oZWlZzY5iXyl_6iKUQibXUO5XMYmgVjMHsOcKIMce_RHhCzd3RM8cTovuYX0Fm1PYgPrd7wNmEbWd6lOl5JP9FM4o3pFQB1Jeg0rEkyOYIbiwI0FbSN3fY4V8IOPXBr86_zIVGvGl8oBtj5pvLsdhJQZlBn03XEt8k9bx6t5QD_gZY_gpNTLm_5sXFIL_4TceswS7PZoOj4ZqlEV_1Dj03GPnkH5kUOyzLxLhl9I1uloMFe1CWnX4diiM4Opy_uuyzEFB1YCwtakPet24IK0zMhf3PfPX5l7czoz-EZWGBCyzKUngF1if6kgZgm15M4i7pUuqTt9BVf1CGvboE2E2uD3vqV3HgA2uTp4io806C8hXrCRUwGnFpG3SUDo3SfLkJc51dxiBzEsizq8TqPSp7j-11rnoSAViFCdlBgOvaZ2jK1V13cnwEyxib_Qg0XYDhipVrYyuNrtL17IRz1wB7aBlCnOADsJ3nqzmxx5p19fmn2-BNFz9BejaDAotX-oJ8hqZnec01Keuz5KcjkTrnS2YQiNyA57KxhBv8lMOH91s97SsxML_5nI271fqCBrU1ZDvtp9H_4ek3lOsouF7wYYvIj5zlf9mpIfXo9xqilwHOaKiH1R_93Yc_KFizYI5_v-rfrm25Iy7Sx0vCjd02udqZPjw0BTLoOL1q8RLMFW7vEw=w727-h969-no
It looks like the 34s rub, but if it does it's imperceptible inside the truck. This is at full lock which is a pretty uncommon situation, and I wheeled with this setup in Moab (the Bora 0.75" spacers did the trick) with no issues whatsoever. If I was smart, I would have analyzed this clearance more closely BEFORE I ran this exercise, and if I had, I most likely would not have tried the 35s. :slap:
psjjCwWhPweZCube9_y1ipFRIYzXRcBIeZMyjCnvLVHx2DxhNTEZHZwRRZIjUVfqgIiFe8E7lb_ABz2lVANvzAxEFe08Fxhjp6L0MJd0_rnCtqtciwQMfZBMQfccLF4rDOdLoyfO-fjm4M2gmytKyoXpRUeHf_DgJLi69Hpb69yqaTa7p0t0Q13XnqibJnFrq-m1cCaNtqJRdcpDqJ-gn-P4yFpzX-aEbZ91J8TW6ug2Mk70k07djqrB1727jG_2-_FUZIrdtNdn_GoC9mAn67GP8D773oydpMqdo0sK2FlEmeJZZm-vhHGCu5ZRiHVOrqJcAOg23tt-njm_pHHLPlf2Z_lP1vdELr2aUyZDwNsbpzjSg6ro9xbbjAytMR96SMo6v6u9xrI04sck_accwUrTZA-UHzCKwXUl0sYOmjgWE-0J_-qrDVsFuHmyXNKEJSXnL9FPN-yo3fb7KocjBxiQX_p9YtRoxM6gy62h3bIv1nbhteYH_7kM5kWvokZm0iHP6oN427HgstBTLZILtd5dRh5rRJoXXxcoLdaBbdEI-gRU5rmvEjfRr_gMc9mKaIw1qPkq4GaFIbi7mGXWbBlTvJvvTJTDBEOQ54oGhS1AvZ7PcWHCWaapoH3YU1ee3d6bdgkhHXzo2l2dtV2phZM9Ts-B8zPxNAtEVNLkbxCYx-dQE_SWYSe5lON73wPIZGn9QMJ_smV-ewPHXR-VCSCAvA=w727-h969-no
Here is the 35 on the passenger side turned as far as the wheel will turn at rest (no one in the car forcing the turn). Clears without a problem:
qRXBwXjFofSt7vj_Kap1nmCjcQfa56psEzPTM1Qep8_sCGh8IjVW2qpy_oEdgvLUwtD2B8F7YZeb0vg8TY_RICEbW68R5HNDjUVFmp7_MTyvXjGIrd5ykpK6xM3EibBn4D2IY12AQpU6sstbl6cDO_vd2XAlKTNatlxFg_spkCgLsB3aLb9fTV6BeOeuT8dQwAXseZ8OJdIzu4qIElFhguwCl6HgJVyFoDcp5mVD-yXJ_wAqmIGQXaYAWr_ak3hgp9vpUkwk7JHW5EYjraHEf2nPrEl0GENJlJkt-D4WojnCx-CE6Ewtr0upxKfIxu7T4cXkFevNeKgG1Gcnxf22v1he2xnAaM8b4ICv3Vy-s1CtLrQcTNKNaHIWlJE9oZikNTcDZSA_jUDc6AaemkzcS0d3D5fvVX6520L7ZMBpwlXM-0nGymODKFBf2sVSdirPmSZpKn8G8u9pwGTfv1HBomIGLdTnxZotVoOntCAbKbTeBKvLVwnlkneLg1FexCQwYsSvvyQgrGg_-uixtW3fxD9K-zWGEdpUEKujXZimcaAja4f50mZ7Wu4_3HDeDtg5AShaqixifmPwjhNtvrIYSWyGUrJuUscgKXYJuWB5sownQiECC4X-QN3PoOT28XRg7dmMAHXbmn3dBoMazVCN984xFZ_kb9eioSMTPdAPcObPy7pEl48luEjgG__Ep4CKIedOj0QFGG6dje7bGEk5TmNNrA=w727-h969-no
Funny... About an hour ago I rolled one of my 35's next to my mounted 34's (285/75/17) and snapped a photo.
This height comparison is a visually off since my mounted 34's are squatting a bit under the weight of my fat pig truck...but the WIDTH difference is striking.
2011932
One more...
2011939
Bottom line... Everything works better with 34's. Got rid of my KDSS relocation...replaced my very bent end-links/bushings.Truck is MUCH happier this way...even if it will never look quite as beautiful as it did on the fat 35's. ;)
Good stuff, Matt.
THIS...is the kind of real-world comparison that would be great to archive somehow in a re-vamped tire-tie database.
I saw some other LC200's running 35's and what they had done was cut the front body mount casing and re-welded a plate there to get the clearance.
I am not sure if they were 16+ 200's though? and they didn't mention kdss issues.
It seem like a substantial $ difference between 34's and 35' on the 200's.
FWIW in my case I was nowhere close to hitting the body mount. My buddy did the body mount chop and welded a plate to fill on his LX on 37s, and afterwards we both wondered if that was even necessary. IMO a body mount chop or trim is not needed on the 200 with 35s, but that could vary from truck to truck depending on alignment and unique cases.
Here is the 35 clearance against the body mount:
cdpwhamx234mGTJJtpA_uZ5IFc4hnZfegz-9pWtd7JzY0ysYvabgjdbRd4o5FSdn_kPKziYmeGTxkDNrL0jqBwApxpVr6_3J_CxZ2ROeodbiHez9XB3EK-XJsTfBR6vTNAbXd7BSHvcWpywXioaGZI6USckGvJ4DCFGGh-aekL6ToPuS5c_2flkpN7RkrcXOfm0Cq7-y4-jQV1Kn8H8OOABF7mug13rur0iLmAcVVT4XoSaxhx90ggEc54ALOvN_SPbz9hwVBssMUgALdyM7MezY3u5TOt4AveoQUWTfig14pVSpHlTLy2j9uPCc9HHmK5ZOVT6UBTpBv-uAGf5UvgMck84-zo9Bu_Rgyw0tOaCeZfmVMhiyzrepsAHzBCXbjSFgqK09dXsZFiGfGBN8YEbqiAWNTxbyvHdm6w39duu5XFJlBElgp_dN1ed0jrm4i3HC-Qvd2lqsPcC7kGv6iFhyiBQixyQYZkHj81EU-MKMpyOoAJjCRUeyvlOrAQURl5mxWrFDCm2_z2iCO7DbJr6vJlLqlNbm0pafMX4c-ZEYT0dyVvDw_7GMFhCnv-Yyg-Xh8UYmNknVO--gLL_vyw7UaQdSa5JO1XvJm0iRLyUJOhahNuQe9K7FhdSfjByWAHq-h5XYHcuDNoCf1BY6a2-ZcERiwaH71lQQMj_2C3vN0oPp3lByTlY11yFcNf1FvdRoSVWBF2pP2Fn5DeLFcuKhTA=w727-h969-no
And the 34 clearance against the body mount:
dPxPlMoxN_3Op7p_8qbWMqLOytns73Xx9WhzifqWLwn1n2IY37Zun22gOX-ERs_blNu9KnJq3g7zfDYS6jofBujuSZkNlk-zSKu00OVIxg5sKv4tTIvHVie6WQkqwK7DzOlkeVWruCg9e4P1AuZqhKOjNw3VhDVLpvJW60v-2SIU0_SjFpGdpknmbeGcAj6Fe-J4FSvmwXMgoR8ZvLgyeSGFwvssEi-RLlY1JsHP2i3nOGbDRIzHN-P41HAoBXslbV8-eQNMag6945eNuRY4jpPuLlhmuvJ4QRFTRkbL9njFIwrthqNmCyEWsEynNh4VBIotyWUUZsQU5yVUFVAjn-6mu0SyVopX3uH9NpTAPkfNvLg2ijE1VoUQtRTD3__bIcCbbFgVmrhYX77JPqa2N2ISUirJ85ZNOeajKg2bU8blLc1YpvelYWhGo6WyzKbqCJVYQYPdrYfNupOmwqD7AakwI8sQNOVTCXqk4HUplG1EMGuPJK903TAzLZxGeWqaWDCek8GRjvCzuyDxHfNcvOMwOfDhYakDgs2CRiuL7MbqcN3TExC7KzyzSdZ-FF_niOQnBg7h7yZbmwsWNT9ZMaZJ_o1JPi0fc2KOheWffsf6eVh4TGI9uaNNEBfZaLox1lOMz0yTX7sAlUvu_kVLCI0qpoW7ktLrpTsLJVSmdvMCGTspw_QsC52Jeb8pF6DsQt-SxfXA0wysfmU47bgJHFcrmA=w727-h969-no
Above you mentioned you had to trim the front fender and bumper when going from 33 to 34. Was that on the OEM bumper and fender?
I'm asking because after reading the above I'm thinking of going to the 34's (from my factory 31.6). I have the ARB front bumper and the front forward inner fender trimmed to fit the bumper, with that BP51 two inch lift. .. do you think the 34's would fit without further mod's or with the 0.75" spacer?
My 34’s fit with a .75“ spacer and similar setup to yours. One of these days when I have spare energy, I’ll take spacers off and see...but maybe Matt already knows.
35s (285/75/18)
34s (285/70/18)
35s
35s
34s
35s
34s
35s
34s
Screw the tires, I want that bumper! :p
Great information, thanks for sharing. Beautiful build.
The trimming was only done on the stock front plastic bumper - I should have clarified. In this pic here, I was totally stock except for the tires and front tow points, and I removed the running boards. This was before the trimming and was still totally acceptable IMO, but a few days later the lift and sliders were put on as well as the trimming. You won't need to trim any more if you already have the front ARB bumper. I ran without the 0.75" spacers for 13 months and had no complaints even from my wife who occasionally wheels the truck. I think they are a nice addition, but the spacers are certainly not required.
xvGn4jMRoZYyH3wUp6WARqFDo2YigqHymfd4qRmxiC6UidHHnVCZo9k7W9KBZ6KOzFAvYuhooSe89ziMlf4xQdwLEmTmLDWzBOObFRfJDTNdUy6lacW5BPrFtyLti_E1NXiWHTrFrsUzKg1RkWfD53o_dCdYk75Om5Glk24noVRoLvNeJF1KxpYNsoky2TTbpjvGaN4zjLSXagKrQw3u7hbh6Ix7OhfkKw628Zr9mcOCs5Bn5Ll-lKdJJVGCtB9s86ci54sWvzr1V3iJqU4I4jEWkbc1TA9aoR_XP8VKxCCCZ1NYlQKZ09dkagFLDk4fkr7K3igmeMmMLyHbjUD_0zDanqEaciGQlJYE6_ArVLfwJs9L-mCPXB2LTC2fomj6D5OJpS332BZ9crDVM9a_YbaRUL1HdyUqm64jrnVVSZFp14bJFWgWip8QMFyfA805sNP7uN5c-mhZaxtmwucaa-HS-8MR8RKFReVC-nMunbwpp_i6ryn8kSb0ZUxg7VvaR8RMgkQnvsj3xsMrah6AqiKBkMO8t6oK8ObJYgEdjGqV4b5SRvah7249e2tnBqxZh30nvVPc13ZCoiG22jr10pri0QIE0ir-qrAgGABs5rUMcYLJPxOxC-emHhNFVOaGsmM_lTZZw9PEP2AmaIpxckcUX4E8tZMx5ehAakHh_vN1G2Tmqrr6QEtMWooXMZIQ4ST8PeLC9rFqATTcRJ981psS3g=w1245-h970-no
In this pic, you can kinda see where the front of the front stock bumper was trimmed. It wasn't much but did the trick.
WBjcXJBQXVSTu4fsgPZomZm5JTMLdYvR2mLkaWy26iz0cS47o9tA4lA1g3JQrMTs4E-5qlPqwNJLEEEe-NgeHK4972i4AmyJ9QbzoH8GaDMf6LN2W3o3YcZJERfvDdRsFE344rPl_8b9JT581MnUdoWJEEe0viqD1qKxA-4fjOukDOBc6t9t6KoDnll5rL6RzB6-W3i3nZitBDETv6QCz-w1gba_CGLwNiBVjWct6FBdLSBaZqRdWE52ae4GGZOooMZhuno-2m8d7PZz_uxW3NyfYb71FM7kC1pagJuVqcT8aP-SbV8I0kuAkvlldOankJQasoU8S33FagSBZZEE3xCAIYeU83n-MJa9F_oQgJNu2oXC5P2ZI_wajmHswfefJzrbGFI3f89JjT3gxwycmWrLLhi2mKwav2lTfJBLES-sM3VYFjWVIYLdLrZPHe69bD7eQUAO-PjZqcxdzM5han9b1RkJwrIO-svf9w-jszs215-q3Cli3oGA7-QraZ4OVV2_XRI8mxFGS-lprMK-9Fda2-tlg53mNssTQE8lNXBgUwzsnmhrLPpISebi_HHnXozvjFJRHY1KF_b27mwEAd-k0XzVFCOX4x9Xaepd18Bbf8VJQ4eJEt4MJi2KQ7WVFMz8cU-5CT02TIN9cmuOoGThZ3tWfEmDCrzMmAmWCFVFc77niwHrUCGaKdOOTRMr5vXFs48xIe_qBuHv2M8gPqBBPA=w1292-h970-no
Thanks ! .. nice write up !
So, I just recently put on 1.25'' Bora spacers and my 285/75/17 Ridge Grapplers on Rock Warriors rub on the KDSS at full right lock. They rub so minimally that I'm not concerned. Additionally, its almost like a physical reminder for me to let off on the steering in an effort to not fully lock the steering.
Nice thoughtful post! I totally agree that 34” is a completely reasonable size for TLC.
LX570s don’t have KDSS, and thus are a bit more forgiving at the limits. I have 275/80r18 which is a rare size (super swampers and kenda) on a bit more spacer at 35mm effective. No rubs after pushing the fender liner forward and deleting mud guards and some inner lower back fender trim. This tire measures just under 35” on the truck diameter. According to the scrub radius calculator 40mm offset would be slightly better for that measure, but I already had 1” spacers.
I haven’t had it in high mode with full stuff and the wheel turned out full , if there is any rub it will be in that situation on the outer front wheel well.
One more...
You had the full width 35”x12.50” on your truck before dropping down to 285/75/17 right? The 35 looks super wide next to the new tire! Width and KDSS just don’t play well together on the LC. The LX is much more forgiving.
I don't want to go too far off the topic of 35s, but Greg's BMC was definitely needed (at least at his given alignment while in Moab). After a day of moderate wheeling, I'm pretty sure we discovered he tagged the passenger side mount ever so slightly even with the chop. I think the initial clearance issue towards the rear of the fender he was having was largely due to the additional allowed (read: full) steering range of the motion. I'd wager he would have been rubbing on the body mount instead of the inner fender without the BMC. This all assuming I'm remembering things correctly.
Matt, thanks for posting this. I'll add it to the FAQ later when I get home. I have often debated making that same change. My Toyo's are about 33.4 (I think) and there is no rubbing. I could gain a quarter inch going to 34's which I don't think is much. I have thought about going to 35's as I had that size on my 80 and ruled it out due to the excessive work and thinking thats the line I would need to regear at. Like you said, I can go anywhere I want with the tires I have I just get more dragging of bumpers and get to use my skid plates sometimes as well :)
Thanks again for taking the time to document this so it is clear
That’s interesting and I don’t doubt it. I know he was crunches for time and had to get it aligned somewhere less than ideal...and this national chain isn’t used to working on 200s to put it mildly 😆 I wonder if he had Slee align it and push the front wheels further forward if the rubbing would still be there. Either way, the jump to 37s is a tremendous undertaking and IMO definitely requires gears and a bunch of other stuff that I’m nowhere near comfortable with on this truck. I do get jealous of the new Jeeps that can squeeze a 37 under a nearly stock truck though!
A little nip here and a tuck there and you can run 40s—no lift :cool:
