34s vs 35s on the 200
Since ditching my 35’s a few years ago, I’m on 285/75/17 on Rock Warriors and they are just about perfect. They work without spacers, but I prefer the widened stance, so I run 1.25” all around. Adjusted SPC UCAs help with wheel placement. No issues.
I would like to stay away from spacers. Can I clear KDSS and UCA's with the 285/75/17 and no spacers?
Wheel offset will be key, commonly 25mm offset wheels (or around that is used) to stay clear of the kdss. I recently picked up some 25mm offset wheels and will be upsizing to a 34" tire in the future. With a 45mm offset I could barely fit 33" tires without rubbing on the driver side kdss.
I’m running a +25 wheel with 285/75/17 tires without any major issues. I’ve got a tiny bit of rub on the driver mud flap if I’m turning left and the spring is compressed enough. Nothing to worry about - it’ll get resolved when I finally get around to installing the UCAs…or I could just remove the mud flaps
Yes on Rock Warriors…(offset of +50) you can… but… there’s more to look at.
I only point to Rock Warriors because thats what I know from personal experience.
Other factors—I also have the TJM front bumper (more forwaemrd tire space) and no mud flaps..plus highly tweakable SPC UCAs that can re-position the tires forward in the well.
This is an example of why most simplified answers can be misleading. So many factors to the puzzle of avoiding contact.
It will be hard with the factory UCA and factory offset wheels, it really depends on the tire.
With an aftermarket UCA and +50 offset rock warriors you may be able to make it work. At least that's what I've heard.
Most likely you'll want either a lower offset wheel (+25 offset) or a KDSS sway bar relocation kit. I found even with +25 offset wheels with that tire size I still rubbed the KDSS arm and the sway bar on the passenger's side at full lock. I also had to do a ton of trimming of the fender liner, fender liner reshaping, mud flap removal, and "adjustment" of the mud flap bracket.
Note that in all circumstances your alignment will be key to avoiding rubbing. Even someone else running the same SPC UCA, +25 offset wheels, and 285/75R17 Nitto Ridge Grapplers may have a different rubbing experience on both the KDSS arm as well as the body mount area, depending on the alignment (caster in particular)
I recently went through this journey in my build thread, but I figured it might be easier to locate in the future on its own as more members buy and build trucks and try to determine which size tire is appropriate. I think it's safe to say just about everyone wants to go bigger when they get new tires, and the good news is it's easy to go up a single sidewall size with no issues. *In order to keep the measurements specific, I'm using the published numbers for a Nitto Ridge Grappler LT load range E for all sizes* The stock replacement LT285/60/18 measures 31.69"x11.5", and one size up LT285/65/18 fits great on a stock truck and measures 32.56"x11.5" which nets you almost a half inch of ground clearance and looks more proportional to the 200. I have not read any issues with this fitment, and I think for most people this is a great option especially if you're not doing a full build.
For those who want to go bigger and keep an 18" wheel, there is a great size in a few tires that is another step up - LT285/70/18 which measures 33.98"x11.50" and that increases ground clearance by over an inch (1.15") from stock. In my experience, the gains from this jump are pretty significant, and there is not a ton of work that needs to be done on the 16+ stock wheel and stock setup to get it to clear (16+ 18" wheels have slightly less offset than prior wheels - not sure if that would materially change the fitment). I had to remove the rear mud flaps on the front wheels and then trim the front portion of the front liners and bumper to keep it from scraping under articulation especially while stuffed and turning. IIRC there was some very slight rubbing on the KDSS, but it was totally manageable especially when just driving around on pavement. There were no issues at all on the rear tires fitting. I later added 0.75" BORA spacers which have eliminated the rubbing entirely and give the truck a nice subtle change to the stance.
While the 34s (285/70/18) fit and worked great, I have to admit I wanted more height out of the tire. It was a combination of desiring more performance, but at least equally if not more it was an aesthetic decision. As some of you may know, my buddy just lifted his LX570 and put 37s on it, so when I saw my truck next to his, my tires looked small. Even though I was perfectly happy with my 34s before, they now seemed inadequate, however it was only in appearance. The 34" Ridge Grapplers actually performed a bit better than the 37" Cooper AT3 XLT, but there could be a few other complicating factors I won't go into here.
The good news is the Ridge Grappler comes in another inch increment taller tire - the LT285/75/18 which measures 35.08"x11.50". I figured since the 34s in the same tire fit pretty well, the 35s would surely fit. I ordered them from Discount who price matched another retailer's sale that @JohnJB told me about, and they came in a couple days later.
After they were installed, the guy at Discount said they were clearing pretty well on 3 sides, but it wasn't working great on one. I knew immediately it was going to be the driver front tire interfering with the KDSS, and I figured with a little tweaking and maybe a new alignment I could get it working well on the 35s. This is one of those situations where if there is a strong will there is a way, but I quickly realized I didn't have the will. I tried 35s on a prior 200 once, and I had tried different wheels, KDSS relocation and an alignment but it still rubbed pretty bad on the KDSS. The relocation kit also puts a lot of strain on the bushings and didn't seem like a great idea in the long run, so it was out of the question this time. I also considered different offset wheels, full Tundra swap, and a few other ideas, but they all seemed like big money alternatives for incremental gains. All of the options also seemed to have compromises somewhere else - the KDSS relocation is hard on bushings, the Tundra swap requires CVs, UCAs, LCAs, tie rods, rear wheel spacers and then the track width is ~3" wider (good or bad depending on use), wheels with the right offset to clear the KDSS would likely contact the fender, etc.
I figured it would be smart to go around the truck and measure to see exactly what the gains would be with my own eyes rather than just trusting the published tire sizes and running the math. Turns it out it was exactly what you would expect and the overall clearance gains were 0.5", so the next step was figuring out if the half inch gain of clearance was worth the cost to make everything work right. On top of the cost of the 35s on the low end I figured it would be about another $1.2k to dial it with wheels and alignment, and on the high end it could be significantly more assuming I bought new/not takeoff Tundra parts.
I've had trucks on 35s and 37s in the past, and while there is no question the bigger tires make many obstacles easier as the tire just rolls over them with less drama, there are definitely downsides like the additional unsprung weight which makes all driving dynamics (acceleration, braking, handling) on the street worse, extra leverage on mechanical parts making breakage more likely, wider turning circle with the extra track width, and makes things like adding gears and lockers a next logical and $$$ step. Overall, I decided the jump to 35s wasn't worth it for my use, and I've gone everywhere I've wanted to on 34s so far going back a couple years (had nearly the same setup on my 2014 before the 2016). I love to see trucks on 35s and 37s, but for me and for most here, I don't think it's worth the trade offs and extra expense.
Here are some pics showing the visual differences and clearance difference between the 35s. Both sets are brand new (I was able to return the 35s for new 34s as I only put about 6 miles on the tires) and aired up to 37 psi on the same surface.
35s (285/75/18)
qs0FZuJg9uPp3plKteapEAVQ__aYJvZLX8mJUCrWvQaZjWh7FOobZFQEWtOaW3eMtScdqtWgVrgWxfJcxWBEqLNK0EXwVxlKIYzw70vz1eIAMZzJlYx37M8_5eJcyj7ZWXdfi5FraOfbWCAmrvq_obVE4fEn5m8c5EO0RWzILSlJoJsLDveyyfmVa-xLGwNhsKvDQxikhzKmoKuFGTgioWqJHcXGWsMCQLvLcvIjXfq2tDOfcz6_JnNjs_kQxVMKm6iRlPCgu9UyTArRAi6WYm-uvwfQPKLbvdEkmqoeW7UqZLzj4b14en6ucheW1G_NIrZJ4wVj9Mg1EVn4TkbWwj5bsHV3D9deYtscPaLMhvU0IsaiC56g7nrs39LylCZh5AtH8FrlHMJI8aIzNfMxSSgpCIx3R1sVT6WIw4OHw1BU0HYoxPzue8thEaTZWv19Z_-fhpmIraTOMIw4jjS_iSqnVEC3Gi4EDIIZi_6CyhurQRAtfH3uhfFH4mOYrFpwq0WRFsaCYd-CM3TZ6IQLFJsyYMwkbY9AHp0Elf_BkGPrd1wC9cXPnrN-1aGe8wg4yfridrK2z_oMy_VMZ372sd5zw4KofPleCg7HA2jb1s6Hmyc4E-L3g4ZSLWvJJndw0AgyKWEnlUKdFhv68pwqQdMCW613Pmxl7PSZdtltplYZR2hJTYQfcliHExtu29azByA5a2Bsc467V0kS_wbAcZU3hA=w1292-h970-no
34s (285/70/18)
APW4UmB5fRBTFX-C89f41Cd7-HJKNnzkmFoviUEnzP0UkSEu65_5AdI3mw1Ox7IeKjA90-zi0Noc2JO9Dgh3xGSYq5MFMpKJCB52mrM1iSsFMkB7BnCBtOe8FETU_vZzSPSP0QKyNU3GRD9jQ2crScR5xfuBJRMxqz4UExzadVkWQdXy08Pww3DoR5iIS_nTabQsEHWal4aQRsl2w9CPvBoGKNKVtdPE87d2KBLM6s4746GuqpnkeMgNdskUr4KGpDySgz0yZJMXXHZOaKz3jlh1e8tuI9IaCKIWEtYyisZ1CFUF54VdqCRbk6PtIQTTm8t3ZbrdzD7CIPojg565_El-eN6Uf68sMF-gGIJdz1AFw7JAniM9TSHUzR3Y31m2LtVa3f4YL_7jRUIL8PXrN5LFr_B-ZcyXvjFQB2ZI7qouq47EADs5ZPA4HyW2sQVjZxPeeHv9AnelH-bcF6CpOmQen-pEkqQ-7gyCa3h4UjPR7ouV1bK89VyJTSIPSisa9bCHg49ZAGp5dgG16NkcfCXP7ODYjyWD8nDL-u3ESwGnhAtn5cUKifCt3fe4zi5DByFRSXScbsIf1V4V6rMPPxvCy3cy2m60KhyY8b_qWEk6rhUoZs4ehh4R2LDO1pys649KIc89hmA9qX1VITX5QMH7MS4SfC4ZjaYnukXNCQkvlh0i8EcqhYYuwFczsh-nAaiIcYd2JPzbhGvPbqI4m4dbuQ=w1292-h970-no
35s
SA9BE3l1NkySwpDJmgEG_fPpzv511ZL42vQCSEODfDGtIJjXfHlrUNS-J_cusrJT56ZbYvV1VwxnH_3o9RlZg9YF_D8vnGKDpeG23StSIDkQ2wkK5AuLMJWOMWTfjz9ZKnkWU-HFh3xEhNsH5z5C6uZY5gQzVQt059kKIbuWJsKrFBPeGEzhkbStM4f64502ik6m_4uZPSnTQ2Fncsiya7apYSB2jCpY2L1LIcz5zOTregfaU8-Sf7Ye2RGwDkydO4nQWaL_XoZ0pUe3SvEpvmj5Ao6dENCL5pr4UR2X52y1vdmFhNtpXhUaNc-HE38EkH8G6_jvud8Yt47sRr1Y-YkqztSsG9ywQ4NRzzKL3hFXp1YuT7GFT4ajeZv6RRu6Hs9zFGnf0lLkPOT8PxedgwpNrbYOQB1OnEKy01MDWoEpUkgJsm7boTRhZsnE_2BzuomA8Qfwy0wTHHDo9_o70M6yevxrJADLdXofmyNWrHnT-vD_lWDXm3kluVhfGuwkN0kzEOEQA3xPT9_iGBv2ZnVtwen3rYMMOKzFCJQGHXx8aY835pvCvVRHkyvibAtL_tl1PtnlBNb-LQgbdZzUYf64WDeIMt28toMcslm57PgLg_T8EwEkwm28hkzvKnDNudzR41VPzCUusufsAifi1dmEgK53IA73M8sP_REo-CXuEDyQjT8bUQDE5YeVlyzsNpsWATiFQPtWyZ5abaBMZut2fA=w1292-h970-no
34s (this is the most obvious view where you can see the difference in size)
vr_-CB2nlMnNvJuaUpHLnspELcCZdCs-9tl3hHYkI0odDgobsS3gDsFpGGjwAgRhFtR6Qd3s8i3aLZzvm6IRkWNTG_-Vez2JVGl9fjDRdcME9j4NiklFEAY3jpiIJI0UgQmlhLqO70rWxpIkYWVmec40WvAZJvPIPOESxnlIKVEhxDIm3GLa8lCvLA0wVeTJ4gW0ZZ7zL5pFOFdzJ66EJkL_ECwAgV6nFGTfNNQBS59xEgF4pUmra0TQMQ7GR2BAXv6SArHwZINWrJcLI5DnUVEQYfHIZE1DZqSP_Bb6JyoH5HUhucmj_OzU02sPlwoiwjenLX4_XE1gwmMmZ9xWBKXU5hoW6KkoWCOp0Z1vGZU1Z4k8ZxImbYyCOXXTKarjK9PIxrT-YcBSLgEjdhOXAeHKMWWaA4cy-j0ZG5qWyUGn7K6Qe8he_BwVxt5WkHJQ9rB3_VAzPQ28y9Fr7JCBQ3HnZHHwabMpR4825VGfk0Vs6ozU4uL4MZ4cnxvWO9h4n2fEQGTTA8wd5_XSQ4u1wFzt4zs0Fe14Hd4NJuTVZ2x05d8KJ2BAS89q2jcoxJEw8zPe__wAAAwlCXzn0GIj80M_EZVG4DgunKzsuTVfNJv7Nn-0BrWDh8giXpZsSo2JXvh_e0xDwjumXt3rJ9uACyG9-EBinBFkfKbsCIJ2JDgqaToVToqtE8lG19eXjCv_6QLYhiHfOFwaSDYrtYA9WxL1BA=w1292-h970-no
35s garage clearance
nh_FL9TDHaX2BFOQXdm4ILxddCuFeusknwu4RNJ1Gz15XI_9NPP1H962vbXTGUiT8VzgsPBGCLIiQe-yJpWRtBWDb4f0lsxOLUUEri4PkV07CYHV6lXgs9lvaVYMjqzLV6_U6FM2vdf3uGcjooXHbVYs5JaSZEdnVZ8HBvPBK7v4_ivZGSt2EjBGhkfFnhoO-18kartp2JIKwF1AK71aQ-Pr5Uu3-OAOg35ULhq-5j7Urw_UlRy50j4EeTfxqWe8rWJZK10V2466C90n7JLWDJg3_4WUS-1NQGUlDgL4Jp8e7zbW8G5WSCKK8LNDEU9_cv63I4ubh3PvoV6GLTPBummBCXfSmHXIaqck2GUM26yMxk6m8EfsIAixPF5_RsMfcGtl9HbuJj2zki2P0ANsQA7OE7nfBqb1AW78Vf_OJ5AUAXI_nZx6sQMN8QCtgruxbuNPta24UAu3Ctv06kS8y73ACSypjn2wr0kwgYvGR4tpbrr3fSjNhDbgCh4Zgg20xS-wT1xJwEIkXqICqB-aE5WTY9wA3i9SRjeiGcQIwHXnQ4vDE3u_3kiwxMkm2yB2oHx7yOAWL393ebB799JP8mHiuCglFiK7q6dIvbLumIP1inbv2FQVdG1guG04U91eebgZ3Q9hwEdnkplhghJjAnNB3hiNYH5NSi7YItks7czkTCdaGUIpfHXwe5JIX9uaAgLd7GWtGa3kOEaK2kc5gRM3tw=w727-h969-no
34s garage clearance
ZVN00dbdCh54suVoeuAMxqfuuXIC2Bx-lcZLQvq6z_33QQu9pTUxPiPhZ3AHbpbXyJg-TbvQxjGG7azUWnOOqGE9H5fkxAHluaPEEU3-zJxYoCVa1w-Fi5nlaVWYOVkez0f2Ggbzi9gkha-Q5ebzANvz8QepFwQStY86HE3jBLXS6CpKpbhtbEJaXQBKk8jC5azZ2W3fgD888gFi3hg6Mi_1JHfwflWBmz13QYHf76BVxf5K0wEIvWy5aAUwKdHc404JtqjGrcFq-XPmi5dkzMsHfrBDvVKObLcmibUY6co4jodKtoid-gF2X54wFDWqKbPGAytrS2bnxZQUDuOYb7o5zp63iaIwzOWXM_iEoSghqrCQgdZFhop90oSK7fuZguUDFnUMM8WV-N_wb7C1BpULp8qWPWV1S9mlfx7dKx0RIT421GSzdHT9mTbQFpssu0nNfuLHks7LoGdst5u9RQC8pM07HZJaVKhe9R48nX7OcBc5HVMiNZwv2l18eqOHA37BDo2WVcizRxPESn4uz6-CjFXU6lufVQqswEkSbN2qdx7_CY2vY0aJmZNPlPDHXQtbQ4Cs3PVlExC0v6WjQ1gXQOBAE7hgdJpqBKpM0zcIs8TlU6yak0yUB5YnDPoB6FE_OkAyG-Y4PnTXT7XfsKmm9PhRuzvPHva8gBwFlLxZHm_xmgL858qSEHCkqYQZ1vxHFHYigd9F5nu49CrvdodArQ=w727-h969-no
35s
Gj2ZDfs_6DNv9v2SWA5alfb4hE7IteIJlXjzmOdJI7YRewBn2uJHMx7_vpHthnnROI_pvXfDt0GLj9bU7N4PGcCLfKwLZla7SQEa5BZzORQv6NdyBLNFiDdnC9ki4iA6uVSrJuBuByPNGnTdbZr494rpAvcpHo89M21_gHQK9e9q8DfjELgqIFv7Z1zlt09HISYSD6NHcdcfrq_AW8UKjGJ-Ey4dS-PymYVxphZ-DBtSF4o3xz8UyV7Gb9tSxLBj7UrmNxapjDzMKsJvvuQ4L1cpEmLoE3TYNJKgXbT9rQPM49SFYFbWDuFbOe30H2wXdppa-l6NzP646sICF1R-eO796aD7bY4-0z6MDhvuBIFA0d0O-jN7xy-YiweVEENZTOZN-0L5Y7iWTulnCiaukWN_oJ5EWkDlbXgVBzeLLzuXn8PpM1kCLzUIHQs9LKoAhI-s-yxPeUJCYZq1hRwudvrJcDPcRKSlHpWJrLK4qzDcDoPiws94Lswe5FnTaRWo35r8FtzfRQEpFaGslffQWAYob34qbl1Nbiy-GY3Uz98_4qEacF5pDTaWGW-1Yc6YxZ3TctfTAZb2v-LIXYZFnxeB-OKa5lvsHwoMiIAmf4LgWMKP3sz6ro0Yu019almr-DzWRFeQeZ7L3CqellF-OF14WJHEP-z8OSeVZVhd4aqeXofhB18hFPwydURhD_4Oai6SfgMBL0HatpvbDq21ZlHrYw=w727-h969-no
34s
F7CCCzLkV3IAtHTCTqIHqRLYIEpURNPfJ5vUfQ9Jgg9qX7dBHYrYlqtxTre9TBa0S9wnr_8HpRugjyskX983ixza0yAb1T4M_eLlnctcmMImpgjNSSrOmftBoCc0cPccHqljVZMH9oLEa0N__kkIl_Wxw5o_OwuGnM_PTyljzok9r738OzKLptIjFkQgfhDQAcX-AgMNPe_ZbkZA1NZCH53n69IAFWFUgDOHXt4Cmpp5TOOcpkJZzffagMW71RM2EWS46jxDyqgbHVwGcPcJGklw-ejd-jR05JXQqEiHg_fDwKUxl7QquZsUykhVbFLT4sZnSUmNV5RemhlDhasRo2mAqUbe9UNyjY36_-roFNdv3QGO5lusZ0tRGAcPuuBupRFlFH5vj0MqId3FVER09mekAs3rx_fPSkfi5NUri29aqz_TB5zoEOe45Wg4WdZuGwo1DE1HXnngiYLEwAO_igr5Pyxu_pN12YmBIPV8jlGSLJcXwTmW1sN3U_-fb7_rqQl75ZbYUic4P23LrAUpwaPqsP3MNzok2cVY58_AbFnywzab9a4t9qqHR-0XxGOSwyftgC1Gy6f1WI-MxBxYuyRIuVYebybAvDlNqWgOvDKldlZT00E5TFfepdL9-BKsIdbo8_q_VQYnYp8xbDWE0u1pHVo616b0R_H9pIxeB4Ex1txnWy9JVTxYeZiBIfzl7fktNODGTqNL58WDM12slMX4MA=w727-h969-no
35s
9Ge1241f6Iw-_qF7aWl9UaDl73jpgOxSNgt_ZhB5gc7xvPrFPyIaDDICRMwVJNayzK3HH_qvd-VuEJkEz1OpY5USU0DiHpSLY92_DuhIkhqmZnLdIw8delKbQZie4jIBWL_m8Dipap13aTX6lI0OQIBakbSj8hFINSCudOFZJ5IXAXau0B4ERNVfRDyiMw9nST7UY9sPq0THLSkLXdn8DZtmYrFwxYdL4nxbXnpM84s2-7JHATfTYv-iS5rZ60SCkBX6d8EQxo95R8mQuHhK2XkTNkSk6bPd6oYcKu6eVe5GyTpVdfqwpjqzdFinJCDaoLPodLoSkapJnWE5pTRdPm6FcRnIOablAYeCWanLGrRfSWwWFqkM2dguYS35XGBzMzNLIk7cbuPITRDqNlrZheAWP3-p7MRcBdMNVNORYp5ZKVq9dzEb5EsTHDqctMN_rtZuTKHDoYQf1Pz8Qo1XpvIcf6BSkgrIGPOVMXV5RiHjDNkx94lx_CwZ1xMSKqPeJjkRfWVBkpvMhaWk0tJnc1gnbCrYPHFLwADfUCLjrQLtfjPI_VMj--URWsbxtvL7Z8deY-XaY962R_ArXsKxLI18chfeUbVJCRsfkJEPqanQ0dAkC-y2ZKju5UIB9pTuflqNlGuw3wlorZtj0xAYWVJxJCmWOJz3mPcM2uM6DZshI8P4kiv422jqM1Kz0b27JAIMdrTutxO8jUvcu_snHAeTzw=w727-h969-no
34s
HOjszBOWM5a6lxJ3EmRKXZkDjOZg433TWyXlhb59D3Ea1XNRubLO8Ho4rewzu4QDdWZzxRQF34-F21BonqWGC9_v1PBeghEgR3giV8Nxv-Zv6ptF36Ul38D9Zq2LKBtq6bl5gCqQ-YkQQ6wceRmsePX9D9-SIMFVDBzRZPfD6Kwt_kiF9RRw953P1KsA9ghhCD_lZmWR4DiWyr8wXEveYd8YAO0r16FOqee4MUWtCPjnqfNX_8eBU6g4xSVhG_hW7-Q1KhKE9H2CrIEk9FFBSoFxqNaI1yqOIa-Z_Wp4WaH93TY2LVzJwrHS9Jw94dnRll3LJYVETYcCcMws3CqDZPz6z2b02ntt7qJMLZXWxji-fM_hu53GO4BMq828xJOVTXpM6JpdRf9Ocvqer7jA5SA4pR2rs1EKTDdR6eJKXNQAPXcad590xGrq4cGirkA7SLt1WYcvLZ3N4Cg8lQhpEdKV4CyJkHT6vJNrRBPaAQbJER7PmvhyAnlRosMj8cBhhRbryQEhNqm5v70KokT0zUbuq3q8rCg9WVCzdqaJ3l1E6Ut29_SJU8M7qt9-xU3Pr8Wi-HeNTTO080p9mUVAf2PgRZQWq4eMGcqOTzc4ldxdyvpm4KeA7IqZG_D3I1N7EVugvP-QfHsCigi3QSf6acV6PuoGwkNQLF5xG21pAJMejKKt63n_vE31wf9wXlk7ZhkFW8pM_h1jaTqTTXHzlj5RIA=w727-h969-no
35s
LuUbKxUQHD6-51Vh3Bj2rkLwcOJ78jUsfiBHbjXr33SzBlT438WTQFIgp2c0dec53s3svQJQd0o9zOtJiIiTstmuj50SK8va5gkb3xzetkJIzBjqOmjisexSWtHvSGHYhsJ63fa00mfSVDFxu2u_3bmMyXFJpEYCBn2_-SxTE2X0B9umYrZuNpM7n0kQu_aNCYB0OhedCHKo32EQDH1W3eX7qtejXtw017e_PUhsmFrxinl4Jm_rUPdMavScRV31pr_8BYwxKU2n8q0Xgx-LVrWOyYwJ4D0gCrBRPkK4GWXgbwEF-h-MZnTiOBZEU-xw7FoQuMXssc1M73wnIUgsTSsg-C8_mkDv-v9sPAzb2bevZo5EJTi7SHSWC-Yac0Ws_9PAiyZuWX1sdvb-JwhWDtu15CpSLwiUKeBCPktwu9WDwhdGMDLvrto9xHpFeh2w1HovfsxH2j1DJJc911ND0Sa3M5YTmemKSJD6IdobwaYCLCbnGupvbCAhlZ3NCY8wsINzoR37Q-Wh3euaY3X9otiszIjJdF5Yz8_xeYWLUY7dnTMrjg-b3Oh7MLbkGQTOoXnHrzh7ZouNifCzSrjfvj0xKeX_YKtWVSw3VUVjjvVrpDb2WECeJu8wIutuRZvBLI7v3-wbdxHlDwBVX4Oqy3bAhd5uTwoE7bSLYOldXJiy9A29ad0YfUtENhUJV7FHxnlmaCT812aso5zJRN1VgR9ehQ=w727-h969-no
34s
XM5ljdZx6OyXVXGwFsHBzQND6reRexhbfltObB5iAfl68XQjfP2gW07oyFhLz5SBQ6rcW2m5CG2RV6OI5UZKYN4jNqkiLinubp2QZguc1UbREFhQrgoXM-yh5mY50ngVNN8Rv6syWYROzOuOZRCXx3NIZYW86LQHZNLkOafh8ZZQfesS_sMQamoMUqdKkgGjK2C2m8HdT_bExl0n-r5foxEolHOhr6LprVjU0_5rWzDfxSmcSyRxm6NftU6TOGFHgmIE8VVAl_KhpwXy0HkE4FnCGFjMXwr4q98M6MdoIhg0vyeyFg6nRlhy-DtndreU0bSMDdx7dYcvE1I6KoSenhOXQw997OkLTEfLjOh42X6wy58Th3Gp4ra_BWp2oTdr7W-rE2OHOC55GrZrk8kVkzlGTOMVjzJlp3Rs5BBxrPKKp23W0DArE-uQv-1EjYnpPFK4qV4ACswZa_8TGurgJcUfEuvkmH4SvQSN-4SY8IoMVST3CUv-dC7Y9OX1aL1ASEuuWxd5qoj90KxJOu8YahysTUahsEJOdxxeUM_LphrhBHKY-ijs-kBftMAilxQrwb_jgA1VLLN8UtPLCoaO57lQ9MllMgjiZ_Mi1WTs_80QU-fFHp0zgT8doo-_Ns_6Ck-8BFIn15fhUHRC3pR5CnvVM0xWgJ_8w8grk6RecYqrWrzmyrcEXY1KQ_cgw-wAbvLPpjEalxWUXtGtZeHeiovKBA=w727-h969-no
Was linked here from some tire and wheel round table.
This is late late but I really needed to read this.
Thanks
You had the full width 35”x12.50” on your truck before dropping down to 285/75/17 right? The 35 looks super wide next to the new tire! Width and KDSS just don’t play well together on the LC. The LX is much more forgiving.
Yes. Those 12.5’s were what I ran for a couple years wheeling with you somewhere in there. Only took me 3 years to find your question fir me… ha!
I just installed an Ironman 2” lift and upper control arms on my 2013 LC 200. My buddy will give me a great deal on a set of 34x12.5r18 BFG KO2s. I’m sorry but I haven’t had a chance to do a lot of research yet, so don’t flame me! I know it’s a really heavy tire and I wish it wasn’t so wide… If I keep stock rims, what modifications would be needed to minimize rubbing. I’d like to just get some 17s and 34s or something like that. I’m guessing I’ll need some 1.25 spidertrax spacers or another brand if I keep the stock 18s. Thanks in advance!
Remove (or cut) front mud flaps
Move front fender liner forward
Try without spacers first…. Then figure out which spacer you may need based on scrub radius and where it’s rubbing
(Note: lift technically does not impact max tire fitting in Toyota IFS)
The trimming was only done on the stock front plastic bumper - I should have clarified. In this pic here, I was totally stock except for the tires and front tow points, and I removed the running boards. This was before the trimming and was still totally acceptable IMO, but a few days later the lift and sliders were put on as well as the trimming. You won't need to trim any more if you already have the front ARB bumper. I ran without the 0.75" spacers for 13 months and had no complaints even from my wife who occasionally wheels the truck. I think they are a nice addition, but the spacers are certainly not required.
xvGn4jMRoZYyH3wUp6WARqFDo2YigqHymfd4qRmxiC6UidHHnVCZo9k7W9KBZ6KOzFAvYuhooSe89ziMlf4xQdwLEmTmLDWzBOObFRfJDTNdUy6lacW5BPrFtyLti_E1NXiWHTrFrsUzKg1RkWfD53o_dCdYk75Om5Glk24noVRoLvNeJF1KxpYNsoky2TTbpjvGaN4zjLSXagKrQw3u7hbh6Ix7OhfkKw628Zr9mcOCs5Bn5Ll-lKdJJVGCtB9s86ci54sWvzr1V3iJqU4I4jEWkbc1TA9aoR_XP8VKxCCCZ1NYlQKZ09dkagFLDk4fkr7K3igmeMmMLyHbjUD_0zDanqEaciGQlJYE6_ArVLfwJs9L-mCPXB2LTC2fomj6D5OJpS332BZ9crDVM9a_YbaRUL1HdyUqm64jrnVVSZFp14bJFWgWip8QMFyfA805sNP7uN5c-mhZaxtmwucaa-HS-8MR8RKFReVC-nMunbwpp_i6ryn8kSb0ZUxg7VvaR8RMgkQnvsj3xsMrah6AqiKBkMO8t6oK8ObJYgEdjGqV4b5SRvah7249e2tnBqxZh30nvVPc13ZCoiG22jr10pri0QIE0ir-qrAgGABs5rUMcYLJPxOxC-emHhNFVOaGsmM_lTZZw9PEP2AmaIpxckcUX4E8tZMx5ehAakHh_vN1G2Tmqrr6QEtMWooXMZIQ4ST8PeLC9rFqATTcRJ981psS3g=w1245-h970-no
In this pic, you can kinda see where the front of the front stock bumper was trimmed. It wasn't much but did the trick.
WBjcXJBQXVSTu4fsgPZomZm5JTMLdYvR2mLkaWy26iz0cS47o9tA4lA1g3JQrMTs4E-5qlPqwNJLEEEe-NgeHK4972i4AmyJ9QbzoH8GaDMf6LN2W3o3YcZJERfvDdRsFE344rPl_8b9JT581MnUdoWJEEe0viqD1qKxA-4fjOukDOBc6t9t6KoDnll5rL6RzB6-W3i3nZitBDETv6QCz-w1gba_CGLwNiBVjWct6FBdLSBaZqRdWE52ae4GGZOooMZhuno-2m8d7PZz_uxW3NyfYb71FM7kC1pagJuVqcT8aP-SbV8I0kuAkvlldOankJQasoU8S33FagSBZZEE3xCAIYeU83n-MJa9F_oQgJNu2oXC5P2ZI_wajmHswfefJzrbGFI3f89JjT3gxwycmWrLLhi2mKwav2lTfJBLES-sM3VYFjWVIYLdLrZPHe69bD7eQUAO-PjZqcxdzM5han9b1RkJwrIO-svf9w-jszs215-q3Cli3oGA7-QraZ4OVV2_XRI8mxFGS-lprMK-9Fda2-tlg53mNssTQE8lNXBgUwzsnmhrLPpISebi_HHnXozvjFJRHY1KF_b27mwEAd-k0XzVFCOX4x9Xaepd18Bbf8VJQ4eJEt4MJi2KQ7WVFMz8cU-5CT02TIN9cmuOoGThZ3tWfEmDCrzMmAmWCFVFc77niwHrUCGaKdOOTRMr5vXFs48xIe_qBuHv2M8gPqBBPA=w1292-h970-no
@mcgaskins I know this is an old thread but I'm in the process of buying a 2020 LC and love this set-up. Ideally, I don't want to have to do any mods to the stock configuration.
1. What size tire do you have here in this pic?
2. Could I run these without any modifications?
Jumping into this, from what I see online a 285/75 runs out to a hair over 34"...but in this thread its referenced as a 35" tire. Just looking for some clarity on this as I'm looking for a 34".
Depends on the rim size. 285/75 r17 would be approximately 34”. 18” rim would have a 1” larger diameter.
I've never thought about that, I would have assumed the tire size is the same just rim size different.
It depends on the tire manufacture and model. There are many tires called 285/75 and they are different sizes, you have to look on the manufacture specs.
Example I run 285/75 ridge grapplers and they are 34", BUT they are taller than my Jeep tires that are 35x12.5x 17.
With stock wheels the 285/75 fit with a 3/4" spacer.
