345/75/16's (15 Viewers)
Especially with a supercharger. I can't believe it. That combo usually nets 10-11 mpg
I'll snap a photo of my scangauge - on my way home from the San Diego Cruisers swap meet I averaged 14.9 from Ramona CA to Leucadia CA.
You'll have that beauty back on 285s and for sale NLT August 2013. Mark my words.
hey can you get a pic from the side thanks
i just can't look at this thread without thinking....
I was thinking about the MTRs in a 315.
Now thinking about these in this size.
How is the power in 4LO with these?
These will just be a set of trail tires if i go with them while running 285 BFGs on road so i am not too concerned with the HWY manners with these on stock gears. If i have to run with OD off on stock gears to run these on the HWY that is fine with me, as there won't be a lot of those miles a year.
Waiting on some flex pics to see how bad the rubbing is :)
With the lift I have, they rub in the rear pretty good. I ordered some 4" MAF bump extensions yesterday, will see how that works.
That said, I rubbed it as hard as I could and drove it out of the rub for 3-4 revolutions of the tire and they did not hurt anything.
In south Louisiana you will be fine with the stock gears. 100%
Side views.
Excuse the water....:D
Thanks for the pics wngrog
I just noticed you were over in Miss. A fellow SEC brother!
I just checked the price on these and it is almost the same as the 315 MTRs :)
I have heard in the past that running this wide of a tire on an 8" rim is "not recommended". Even a 12.5" isn't "recommended" on an 8".
What are the reasons for this?
I have heard it is easier to blow a bead, AND i have heard it is harder to blow a bead, haha.
I have also heard that it causes the tire to sort of make a rounded shape across the tread causing uneven tread wear.
Any of these true or anything else?
what pressure did you run when you were wheeling? everything handle well traction wise?
I just got these on today.
My setup:
1997 Collectors Edition
OME Heavy Front with Metal Tech 2" spacers
OME Medium Rear with 30 mm urethane spacers
OME caster correction
Standard OME shocks
Here it is sitting next to a stock Collectors Edition
Do you have 2 1997 CE's?!?!?!?!? :clap: If so, that is awesome. Brother and sister.
I still have the sway bars all hooked up. They limit my flex, not my shocks. I may get some front "L" shocks and unhook the sway bar on wheeling trips but the rear shocks outflex the suspension without being "L" models. I can almost keep them hooked up to change out the rear spring.
