33x10.50-15 tires ..... what all to choose from in 2019? (2 Viewers)
Wow, they are expensive too. The only one I would remotely consider would be the TSL Radial.
Then you might as well get the 9.50 x 33. Pretty sure the TSL Radial comes in that size.
Edit: No apparently it doesn't. 9.50 x 31 but not 33.
Toyo MT ended up being nice and tall.
15 x 5.5” wheels
New tread
32#
height 32.25”
Width about 10” to outside of sidewall
This is really interesting. So here are my 33 x 9.50 Super Swamper TSLs on stock OEM 15” wheels on Pikachu (1977 FJ40). 32 PSI and paved surface.
Height is just over 31.25”. Wow.
@jim land @wngrog
Does not surprise me. Damn Swampers :)
over my year and years of dealing with Swampers the only thing that was consistent was the fact that they were rarely true to size.......or round
I will skip the size thing as it has been covered for my 33x10.50 KO2s on 60 series wheels. I will add some observations in the "how they are holding up" category.
I have put exactly 30,819 miles on these tires as of today. My 62 is 6,000 lbs as it sits, and 6,800 loaded for trips (roughly 1/3 of those miles). That includes commuting, a couple cross country trips, lots of wheeling back in Washington, wheeling at 2 Solid Axle Summits, and the SSS. I also have a Spartan rear locker which accelerates tire wear.
I measured them with a tread depth gauge tonight and got 10, 10.5, 10, 10, 8.0 (32nds). They start out life at 15/32nds.
This works out to about 4,700 miles per 32nd for each installed tire.
I have done a 5-tire rotation 3 times since install, at 8,419 miles, 16,897 miles, and 25,453 miles.
If I were to run them down to 3/32" of tread depth (the wear bars), I can expect to replace them at about 69,800 miles (using all 5 tires). If I only had 4 tires this would become 56,000 miles. Obviously off road use may dictate replacement sooner, but it's a point of comparison.
Here is the best tire:
And the worst:
Ok, here we go:
Both tires are 33x10.50-15” 32psi measurements taken with the tires mounted on the front a stock FJ60 with OE wheels
General Grabber X3 (0 miles)
Height - 32”
Section width (overall width) - 9 3/4”
Tread width - 8 3/8”
BFG KM2 (5000 miles)
Height - 31 7/8”
Section width (overall width) - 10 1/4”
Tread width - 7 5/8”
As you can see, the X3 is only slightly taller than the KM2. Interestingly, the KM2 has a wider section width but the X3 has a wider tread width. To me, this makes the X3 look taller and skinnier. they seem to fit the OE wheel width better, too. I also noticed that the X3’s are considerably heavier than the KM2’s. I’m not sure if that’s good or bad but just an observation.
I don't know if you found your tires, but many more options with 16 inch wheels. I found the 10.5 width tires crowned too much on the stock 15 x 6 inch wheels. And there's an ideal 16 x 7 wheel from 70 series trucks that Onur knows about. These are 255/85/16 on 8 inch wheels and a subtle change in look. Just at 33. Cooper ST/MAXX. Sorry if this is out of context.
I’ve also gone down this road. More info here in this thread.
Yes. I agree. The 255/85-16 is the best size IMO
