Looking good!
Looking sharp there. I can't wait to see it out on the trail.
Your sig reads you have a 1973, I can't help myself to ask where is your gas tank?
Is it inside in the back?
30 or 35 spline shaft? I found the Yukon shafts to be relatively inexpensive (compared to RCV) and have Warn hubs.Looking for suggestions on dependable upgrades. The stock Dana 60 axle shaft finally gave up, broke the driver stub shaft and it broke the warn hub assembly. Then while 3 wheeling the trails the rear output shaft snapped on the mini truck transfercase.
Thinking Yukon shafts and joints with some drive slugs for the axle. Then wandering if the Marlin Crawler 30 Spline output shaft will be enough for the 2UZ motor and 40" tires. View attachment 1455702
I'd think the marlin output would by up to what your asking of it, just watch out when you're bumping up stuff and throw it in neutral if you don't make a hard launch.
I'd say no, unless you never want to worry about breakage or replacing them, ever.Going 35 spline for sure. I was wandering if the RCVs were worth the extra grand for a non rock bouncer.
