Cruiserdrew
On the way there
Pardon the hijack, how does this 4-speed output look?
A lot of wear. Normal at high miles.
No luck so far finding a 4 spd transfer case. Anyone have one feel free to message me. I have a wanted ad in the classified section. Conversely a local FJ guy who i thought would have one was trying to convince me to just use my 3 spd case. I think by the time i buy the conversion gear and correct shifter linkage I'll be in for the same money and possibly louder?
so I got a few hours today and started on the F engine removal... basic stuff - drain radiator, disconnect fuel lines and electrical connections etc. Man, that throttle linkage is difficult to get access to. i ended up taking the carb up at the base and turning it so I could access the linkage. the isolator plate had its gasket peel - I understand this a common source of vacuum leaks, so whats the best place to get a new baseplate/gasket?
it became evident to me that i was going to have to remove the entire exhaust as it blocked the skid plate - so I got it out in 1 piece and I think its a very good original replacement part. See photos. I was planning on re-using my F exhaust manifold and hooking back into this stock exhaust, but now I'm considering selling this piece and using the headers that came with my 2F. Any idea what this exhaust is worth anyone?
I also removed my bench seat to access the trans tunnel hump and am considering selling it as I prefer the buckets. Anyone want to throw out a number as to what this is worth?
Last couple questions..... the skid plate looks like it does not support the trans or transfer case - correct?
And finally how do you disconnect the cable from the parking brake?
thanks
