200 Series Tire and Wheel Size Database (14 Viewers)
What is the weight rating for the 18" BFD? Was advised to check that. Anyone know the weight ration on the older Tundra wheels I have on my truck? See Pic in profile.
The flow formed 18x9" BFD (the latest/current version) has a 2,500lbs per wheel load rating as tested and certified to the JWL-T testing standard with up to a 35" tire diameter.
Do you have a photo database of FN wheels on 200 series? I have a silver 200 series and would love to see some shots of your wheels another silver, tough work deciding on what wheel I prefer and in what finish. TIA.
Love my FN wheels (18x9)
The 285/75r17 (33.9"x11") tires fit well with a 2" lift and the -35mm backspacing of the method wheels (17x8.5"). Only a slight rub on the plastic fender liner at full lock (pictured). Extremely happy with the look, and the fit. Unfortunately there was a mishap at the tire shop though, and the cruiser took a pretty big hit to the drivers door. Drivers side rubs like a sonofabitch, but only because of the accident.
What was the offset on the wheels??
My LX needs new tires soon. Want to go with KO2 in 275/60/R20 (OEM rims). I had this same setup on my old Tahoe, so I know what I'm getting in terms of performance and the like, but will they rub? Truck is totally stock, no lift. Looked through the database and looks like only one other person is running 20" rims and the tires they chose are 32.3", not 33" like I'm planning on. Just want to make sure there won't be fitment issues before I pull trig.
Also, I'd like to suggest a link to the database be added to the first post @MScruiser. Owner can change permissions so it's view only, but it would greatly help in viewing cut-off text and using filters. Having to search the thread for an embedded copy is a PITA
That looks great. Have you twisted it up yet on the trails?
For those running the Kenda, have you tried the AT2 ?
Kenda Klever A/T2 KR628 All Terrain 275/65R18 116T
-$208 at walmart
I have been running them for the last year. Very happy with them. During this last heavy winter in CA they did phenomenal. No issues in deep standing water or snow.
The tread pattern is similar to the Dutatracs but so far no intrusive road noise to report. Quieter then the Klever RTs
I have them in LT275/70r18. They are basically a less aggressive version of the Kenda Klever RT that I was using before. The AT2 has a 2ply sidewall and is a little smoother/softer then the 3 ply RTs. The main reason I went with them is that i was really impressed with the RT and for my next set I wanted a light 3 PMSF rated tire. These 33" tire/ wheel combo weight 80.5 lbs.
that is awesome!! really wanted those wheels for a while but 6 + month wait always
Socall offroad (rowher flats, hungry valley), would you recommend?
walmart or simpletire seems to be only place that has them
Right on, happy to assist. I was fortunate and ordered the wheels through Main Line Overland before the whole covid supply chain went to s&%t. Prices now are more then I'd pay for the wheels. Have you checked out Tire Rack? They have Alpha Equipt wheels on closeout. Can find different wheel options from $125-$200 a piece. Their search function is garbage though and you have to use different years of the tundra with the 5x150 bolt pattern to filter the wheel options.
I am up in Northern CA, not familiar with those areas. I mainly explore the Tahoe, El Dorable National Forest areas and the Mendocino NF. I have family in Southern CA but haven't had the chance to make it out when I am visiting.
I bought mine through Walmart.com. However if i had to do it again I'd use Simple Tire or Priority Tire. Or at least make sure the seller is an approved distributor for Kenda. You can buy through Walmart.com and the tires may be from a seller who is not an actual approved distributor for them which then voids their warranty. Something to keep in mind as walmart often has the best prices but you may be out of luck with the tire warranty.
thank you so much
i will check the TR wheels on sale. Going to grab tge tires from simple tire.
Hey guys, quick question on fit, i believe these will work but just want to verify before i drop the cash.
2018 White LX, currently undergoing chrome delete. Goal is to mount 275/65/20's duratecs on these. What do you think? Not style but fitment.
Specs:
Wheel Diameter: 20inch
Wheel Size: 20X8.5
Finish: GLOSS BLACK FULL
Wheel Offset: +40mm
Bolt Pattern: 5x150
Wheel Bore: 110
Condition: New 100% aftermarket products
Quantity: 4 x 20x8.5
Did you ever do this? If so, what kind of mods did you have to do with fender liner, etc.? I am wanting to put the same size tire on stock rims with 1.25" spacers. I currently run 275/60/20 BFG all terrains with the spacers. I had to massage the fender liners and remove the goofy front spoiler deal on my LX. If you have done this can you share some pics? TIA
will 18x9, +25, stick out too much?
