200 Series Tire and Wheel Size Database (6 Viewers)
Help. I'm wheel stupid. Is there any concern in moving from the stock '09 LX wheel to the stock '13-15' LC wheels? I'd be running stock tire sizes on Michelin Defenders. I'm just interested in adding some sidewall comfort to the LX.
'09 LX Wheel Specs (link)
- 52mm offset
- 20"x8.5"
'13-'15 LC Wheel Specs (link)
- 60mm offset
- 18"x8"
That site is incorrect for my wheels. By a lot.
I could use some help with RCTIP for my new tires. Running Toyo LT 285/70/17 E (121/118S). Running 40 PSI today...
You're good to go.
The RCTIP for LT285/70R17 tires on your LC200 is 40psi F/R
HTH
Gaijin...appreciate the confirmation. I thought they could be a bit under-inflated at 40psi as I expected these E tires to ride a lot firmer. Don't get me wrong...the ride is definitely firmer than my previous Toyo AT III in 285/60/18 XL, but love the stability. Thanks again!
I could use some help with RCTIP for my new tires. Running Toyo LT 285/70/17 E (121/118S). Running 40 PSI today...View attachment 3321289
There's easily enough load margin that you could run at 35psi. Though something in between 35-40PSI will probably strike the best ride and handling balance for your preference.
Its a heavy burden to carry, but someone must carry it.
And I tow a 3500# trailer off-road…we will see how it does at 40psi.
I run that same tire in a C anywhere from 36 for harsh city roads, to 40 for long highway trips intrastate. Usually staying around 38 after my preload setup.
Really above 40 ride quality and traction fall off a cliff. I wouldn’t ever drive it in rain at 40 either in any spirited fashion. Dramatic changes above 40.
Put 295/70R17's on rock warriors today on my 2015 LX.
Had to delete the front mudflaps and will get out the heat gun for some very slight reforming of the front fender liner but that's it as there is only tiny bit of rub at full turn.
Could I get an RCTIP for this setup?
Sorry for the missing info @gaijin, they are BFG KO2 LT295 /70 R17 121S E1 RWL on 17" Rock Warriors.
No worries.
The RCTIP for those LT295/70R17 tires on your LX570 is 35psi F/R.
HTH
Hello @gaijin
Would you please provide RCTIP for this setup:
Yokohama Geolandar G015 P285 / 70 R17 117T SL
Method 17x8.5 35offset
Thank you
The RCTIP for those P285/70R17 tires on your LC200 is 27psi F/R.
HTH
Are you referencing a different specification source than what @gaijin has access to? Can you please elaborate what source that is so that I can better understand your recommendation? Thank you!
😂 LOL that is hilarious, sorry man I don't mean to be rude since you don't know the background but he has no access to anything special or any insight you don't.
Thats a good place to start, but YMMV. It does not list all load ratings either for example.
For the tire you are running the absolute bare minimum is 32 PSI, but since its a P for P, your door jamb is the real minimum.
I don't know where you think an internet stranger is qualified to give you life threatening advice, but as another internet stranger I'm telling you that whatever the recommendation was that I cant see (its blocked) is dangerous and incompetent.
I can't see the post you are responding to (they have blocked me), but for the record, I use information and procedures stipulated by the Tire & Rim Association of America (TRA) - the body that specifies manufacturing specifications for the performance of automobile tires.
Toyo Tires have published an excellent monograph on the subject of determining tire pressures for non-standard tire types and sizes which includes some of the Load/Inflation tables published by the TRA. Anyone can access this publication here: Guidelines for the Application of Load and Inflation Tables
There is a lot of good general tire info in that Toyo publication as well - happy reading.
HTH
Trying to avoid being that guy that asks questions that have been answered a million times, but I'm not finding an actual link to the wheel/tire database......what am I missing?
Thanks for replying... it made me recheck and realize I made a mistake on my original post. Down the rabbit hole I went.
The OEM tires on my LC200 are actually Metric 285/60R18, not P Metric P285/60R18. My mistake. So instead of swapping P for P, it is swapping Metric for P.
The door jamb on my LC200 specifies 33psi cold inflation on the factory 285/60R18 Dunlop Grandtrek AT23's (Load index 116, 2756lbs max load). Found this on tirepressure.org (Dunlop Grandtrek AT23 Tire Pressure Chart - https://tirepressure.org/dunlop/grandtrek-at23):
Tire SizeLoad IndexLoad Range26 psi27 psi28 psi29 psi30 psi31 psi32 psi33 psi34 psi35 psi36 psi37 psi38 psi39 psi40 psi41 psi42 psi
285/60R18
116 SL
116SL2116 lbs2183 lbs2216 lbs2304 lbs2392 lbs2425 lbs2491 lbs2579 lbs2623 lbs2668 lbs2756 lbs
Here is what I found for the Yokohamas I am considering (Geolandar G015 P285/70 R17) with a 117T load index on the same site:
P285/70R17
117 SL
117SL2480 lbs2528 lbs2575 lbs2623 lbs2664 lbs2704 lbs2745 lbs2789 lbs2833 lbs2877 lbs
So from those specs (assuming they are accurate), I am looking to match the load rating of 2579lbs at 33psi on my OEM tires with something from the Yokohama chart above. The tirepressure.org numbers are saying 28psi / 2575lbs.
Plugging those numbers into the Tire-Size calculator link you gave also recommends the same 28psi / 2575lbs.
I am still curious where you obtained the 32psi minimum in your original recommendation where you were basing your numbers on my error stating a P metric OEM? Not trying to be rude, just asking if your info comes from Yokohama, personal experience, or another verifiable source?
