200 Series and Tundra wheels on 100 series photo thread (1 Viewer)
Here are my 18" Tundra alloys. I love them and would recommend them to anyone!
Sporting them on Pismo Beach, CA
Instagram: @knz_crsr
@mckunz I like. Truck looks good. Where did you get the grill?
Just picked her up this morning from RPM Garage in Monrovia, CA. Tundra take offs on spidertrax spacers that I got from @sleeoffroad. They mounted Yokohama Geolander AT-X in LT275/70R18 (33.4”). Yokohama is doing a 80 dollar rebate on these and 100 if I recall on the MT-X.
305/65 with 1.25" Bora spacers
Man, these both look great! Would a 1" spacer be sufficient for the center caps to fit on the front wheels or is a 1.25" spacer the minimum?
Thanks!
2cam
Thanks!
2cam
Thanks! Personally I think these wheels look better on our rigs than the Tundra's themselves. I can't remember if it's 3/4" or 1" for the minimum.
Are you getting any rub with the spacer?
Only on the plastic piece behind the wheel, can't remember what it's called. Just heat it up and flatten/push back, which is what I did this time. Or just cut it which is what i did on our '06'.
Lovin both set ups guys!. Are spacers needed to run either tire combinations due to the center bore of the wheels similar to the RW's? Or can I get away with a 10mm slip on spacer up front? I'm want to run this wheel set up, but want to veer away from spacers as much as possible.
Spacers aren't necessary from a center bore standpoint. However you won't be able to get the center cap on the fronts. Also with mine I'm pretty sure I'd get rubbing on the upper control arm.
Thanks!
2cam
I'm running 285/70/17s with a 1" spacer with the Rock Warriors, no major issues unless i'm at full compression, then I'll rub the fender/fender liners?
