Won’t rev past 3500rpm and EGT’s drop significantly after 3000rpm, however at midrange (1800-2800rpm) EGT’s are acting normal. Thoughts?
Sounds like you need more fuel, but . . . .
Need more info.
What turbo do you have?
What exhaust?
Intercooler?
What air filter element? OEM?
What are your EGTs for all the RPM points listed above?
Is probe in the manifold, or after the turbo?
What IP tuning if any has been done after the pump rebuild?
Who tuned it?
One thing i've noticed, EGT's hold pretty steady around 1150F until I get above 3500rpm... and then they start dropping.
If the probe is pre-turbo, and under load this suggests lots of room for more fuel.
750c (1380f) is a conservative safe max EGT limit.
I ran mine for 18months with EGTs maxing at 850c (1560f), and peaking at 900c (1600f) under extreme conditions and heavy load. When I had the engine apart there was no indication anything was too hot
May be as simple as tuning the boost compensater and IP settings
If it's been competently tuned, then yeah, question the pump rebuild, but realise tuning is a black art, and takes a load of trial and error to figure it out and get it right.
I tweaked mine constantly while daily driving over a few months with WOT runs daily up a 10% grade.
did you talk to the pump rebuilder at any point since rebuild to see if they have any advice?
In my opinion, these engines a reasonably tolerant of things like coked valves, or slightly off valve clearances, or dirty injectors.
Timing and tuning are far more critical to get right
