- Joined
- Jul 8, 2013
- Threads
- 64
- Messages
- 3,068
- Location
- New South Wales, Australia
- Website
- www.completecruisers.com.au
Good to know. I'll probably go for the 75mm - any recommendations on what all should be modified with it?
I know brake lines, castor correction bushings, I'll check out the panhard relocation bracket IanB mentioned. Sway bar needs to be lowered as well?
I am probably going overboard but:
75mm slinky kit which includes front and rear sway bar drops - the rear drops I got were the type that mount on the bottom of the chassis and also extended bump stops which I believe go on the rear
I am also doing
Extended brake lines
Extending rear LCAs (+~11mm)
Front and rear panhard rods - I will get a Delta rear bracket once the next step is done
Dropped/extended radius arms - need to get the truck back on the ground to work out what is needed - you could do caster bushes or plates, In my opinion, 3 degree bushes are not enough for 75mm of lift, suggest either radius arms or caster plates from wits end. I'm leaning towards Delta's radius arms.
Adjustable drag link to get the steering wheel recentred (And Tie rod while I'm at it)
Steering damper
