What is the plan with power steering? Some are saying that the steering with 100 pump on the 80 is very hard. Some put the pump and banjo from the 79 claiming it has better effect. I am actually going with the 100 pump, 80 banjo bolt and high pressure hose. The low pressure output on the 100 pump is hitting the steering box, so will need to cut and weld it to the other side.
Thats cool. If you do, I am currently having alot of trouble with my DTE chip that I got through Gturbo. The connection in the main plug is problematic, often makes the chip cut in and out. If i had my time and money again, I would use a unichip Q4. Just a heads up.No decision yet. May not chip it right from the start.
Definitely read a lot of good things about the Unichip. There seems to be a growing preference for that one.Thats cool. If you do, I am currently having alot of trouble with my DTE chip that I got through Gturbo. The connection in the main plug is problematic, often makes the chip cut in and out. If i had my time and money again, I would use a unichip Q4. Just a heads up.
I bought the gturbo DTE pre tuned module, reason is that there is no 1hdfte experienced tuners around me so I would have troubles to make the unichip working. I didn't hear a lot of issues with the gturbo module recently.Definitely read a lot of good things about the Unichip. There seems to be a growing preference for that one.
No experienced FTE tuners in my area either! Just going to keep the stock tune to start.I bought the gturbo DTE pre tuned module, reason is that there is no 1hdfte experienced tuners around me so I would have troubles to make the unichip working. I didn't hear a lot of issues with the gturbo module recently.
Gturbo and PDI sell the DTE, so you can order one with a tune pre-loaded. From having @Indestructible 47 truck on the dyno with the pre loaded tune, they're pretty well on the money. We upped the boost a bit because he tows and would benefit from a bit cooler EGT on long pulls, but in no way was the tune it came with unsafe. The only negative is the connection issues which IMHO is unsatisfactoryNo experienced FTE tuners in my area either! Just going to keep the stock tune to start.
