@PNWFJ80 this is golden, devilish good
That bypass line is not too bad, access is OK though the drivers wheel well. I had the upper intake manifold off when I changed it though. PHH is slightly more difficult, but not too hard, plenty of guides here on that one. Get yourself a good hose pick and set of hose puller pliers and the job will be a lot more enjoyable.First search result. Gotta love this place. Now I get to replace the water bypass, which is a good time to install the new PHH I’ve had since last year. Hoping to keep the swearing to a minimum. Thank you for this thread!
Started dripping a little coolant today - appears my hose is a bit swollen at the connection. PO replaced the main/easy hoses but still have a few little ones to do that aren’t as easy to access.
Morning Mud
It's Head gasket time, and everything else I can get my hands on.
My focus is reliability, although the pipes look good with a light patina inside I figured why not. I super dig my rear heater and haven't deleted it yet.
I have the pesky metal pipe part number as 87209-60381 but I can't seem to find the other steel pipe part number.
Any suggestions?
Thanks@OGBeno he prolly knows the p/n![]()
I have the breeze clamps on everything, I like em.@BillyGoatMTB i ran gates green stripe and guess what? The oem clamps do not fit at all. I had to use the constant torque style Joey sells . Someone said there is an oem clamp but no one ever post a part number and I’m not dropping $10 a clamp to play guess work
Do you know how many breeze clamps are needed to do the entire system? And their Part Numbers?I have the breeze clamps on everything, I like em.
I'll look, I think those are the 3/4" breeze clamps.
I think of them like lifetime clamps.
I would have to look, I have moved away from breeze clamps on plastic fittings and switched to factory constant tention clamps.Do you know how many breeze clamps are needed to do the entire system? And their Part Numbers?
Much appreciated Kernal, ha you actually helped me on my brake booster. I pulled these both to check for leaks and they are good to go... for the life of me I couldn't find where the leak was coming from and realized it is coolant so not sure if I nicked a line during the brake boost pull. It gushed on me after a long drive and then starting it up yesterday nothing so need to take another drive."need some help identifying these two hoses"
There are two formed transmission cooler hoses on the left side of the 1FZFE with the ATM transmission, easy to see if you look in via the left front wheel well forward of the starter. IME the hoses get squished down by the factory clamps so they're no longer putting enough pressure on the hose/pipe for a good seal. One quick fix is to reposition the factory clamp to a fresh (unsquished) area of the hose to see if the leak stops. ie: just slide the hose further on the pipe a tad and move the clamp. The ID of the factory formed hoses (no longer available) is 10mm which is not easily found but 3/8" (9.5mm) transmission cooler hose is close enough and will fit. The OD of the aftermarket will likely not be the same as the OEM hose so you may need to use a different size clamp (there are different size OEM clamps of the same type if you want to stick with OEM clamps). Another choice are Breeze constant torque clamps which are considered an upgrade over generic worm screw cheapo clamps.
Very helpful! If I'm reading this right, it calls for TWO 16264-66021 hoses, with one of those by the firewall?This is subject to change, but here's what I've come up with so far(updated 7/6/2018):
FZJ80 Heater Hose Part Numbers and Locations
FZJ80 Heater hose part numbers and locations with pictures
Finished! (except for the rear seat heater hoses...another day)
