FJBen
- Thread starter
- #701
So after about an hour, I got the tranny down. I used a 2x4 across the fenders and a strap to the engine hook to hold up the rear of the engine.
Borrowed my friends harbor freight tranny jack which worked OK, and used my ATV lift jack for safety just in case.
As expected, this is what I found.
And as expected, the seal is bad again. I can smell the gear oil looking at this picture...
Oil all over the shaft and in that bearing retainer piece.
I'm assuming it failed again because I have a speedi-sleeve on there and it's just too much wearing on the stock sized seal. I replaced this seal before I rebuilt the engine. It leaked immediately. I pulled right after I got it running and noticed a small groove on the input shaft and put a speedi-sleeve on and stock seal and no leaks for 10K miles. Without the speedi-sleeve there must have been enough of a groove to leak, or I had a bad seal. I have a couple of options.
1: replace with stock seal, $20 later, will probably seal for another 10K miles like this one did then start leaking. OR it will start leaking again right away. Gamble.
2: Replace input shaft. Now I'm not sure a new one exists anymore for the B series. A few sites show them, but most don't and show NLA. Sounds like I will need a good used one. However, replacing the input shaft, you might as well rebuild the whole transmission. Thats a bummer because the tranny shifts good, has no noises and no lateral play that I can detect. $550ish dollars plus some special tools if I do it myself, learning how to rebuild that h55f and plus pulling apart the t-case I just did all while not being at my shop/house.
3. This I suppose could be a bandaid, but possibly better than option 1. The seal for the input shaft on the tranny is NOK AH 1893G. I have called a place in town to run some numbers on seals. They are ordering a double lipped version (allegedly) of the 1893G and the 1894G which 1mm taller. That will possibly offset the seal lip from the groove. I will probably remove the speedi-sleeve if these seals truly are double lipped and not just a seal with a dust lip. They aren't NOK brand, not sure on brand so we will see tomorrow what they are.
