SOLD 1981 FJ40 4 speed tranny with split transfer case
Inland Empire, Southern California
1981 FJ40 4 speed tranny with split transfer case. The transmission shaft turns by hand smoothly in neutral. Transmission and transfer case shift between gears easily.
$800 for the tranny and transfer case ($400 each). Offering the bellhousing for $60. I prefer a local pickup, in Southern California.
Might want to remove the entire top cover and show condition of internals of that trans.
To me it's actually easier to pull the entire top. Just have to be sure the small paw fits into the lever for the reverse gear. Top your dealing loose springs and steel balls that can get lost. Or worse fall inside the transmission. Being an 81 do you have the mileage when it was pulled? 8/80+ odometer have an extra digit to read up to 999,999.9. How long since it's been pulled? Is there oil still inside? I like leaving oil in and spinning gears on loose transmissions.
I will take the bellhousing Martin. And I could be interested in the trans/ tfr, but won’t know about that for a few days.
Mark, I’ll put aside the bellhousing for you.
The tranny and transfer case are pending and have 2 people lined up. Mark, it will probably be sold.
bummer the crossmember was cut
Ouch! Didn't notice that. It's the little accessories that are the hardest to find. Any 60 transmission can add a 40 series top cover too and will work in a 60 series. Crossmember are 40 series only.
Why wouldn't you just hang it like all the earlier FJ0 H42s?
yes, it can be, my comment is that the crossmember is a somewhat rare piece and now it's useless
At least it wasn't off a 10/82+. Those are even harder to find and work with the H55F. There is value in the L brackets that bolt to the frame. Those will work on all 8/80+ FJ40s and BJ4X with a four or five speed.
Mark, are you still interested in the 2f bellhousing trade for the upper and lower oil cooler pipes? I tried your office phone 2x and it never went to voicemail. I can make it out to your shop today around 1:00-2:00
Per my signature line, I am out until Monday 😊
Are the L brackets on the frame for the crossmember available or lingering on the frame unused? If so I'd buy those if they are in good shape.
I do not have them. I bought the tranny with the cut off brackets attached.
