jim land
have you check if the top of the quarters panel is parallel left to right , look like the driver side is lower in the rear , it could be cause by a crooked frame .
To check your frame , lift the 40 and put it on jackstands under the frame (not the axles) use some plywood of different thickness under the jackstands to make it sit level , then compare front and rear bumper for levelness.
