- Thread starter
- #101
We finally figured out our alternator/battery charging problem. When I first took possession, my dad noticed a bare wire leading to the alternator. At the time we taped it up. Dad decided to unwrap it and inspect it further, and in doing so we found another wire leading to the alternator was broken. After replacing the fuse, everything seems good. Finally something went right!
We've moved on to checking some electrical issues and here is where we're stumped. First, my dash lights are not working. All I have is the right turn signal indicator. We took the gauge cluster out and checked the grounds and continuity and everything was good. We replaced the bulbs and reinstalled them and replaced the fuse. After this I got left and right turn signal indicators only, no dash or high beam. I also got running lights and taillights. I decided to replace all the bulbs in the cluster with LED's. When I did that, I'm back to only the right indicator. I then turned the headlight switch and as soon as I did, i blew a fuse. If I keep the switch turned fully clockwise, I'm ok. As soon as I turn it, the fuse blows. Do you think it's the headlight switch? How can I check it?
Anyone have any ideas on my dash lights?
