Build 1971 FJ55, "Bucky"
Great build. This is where we are heading with our Project Homework.
Looks like a good driver that you don't sweat the small stuff and keep enjoying it.
Long live the Bucky's of the world.
I like the original name - Zeppelin.
Hindenburgh might have been a good name in keeping with the Zeppelin idea when you brought it home.... but not sure that would have predicted such good results.
Well, I won the WCW wrastlin’ title today. My opponent:
Me:
I am going to need to pull my t-case here soon. I have a spare case that I am going to install I think. I may even rebuild it.... Did you need to use a puller to get the case off? and how hard is it to wrestle it out in a 55? I seem to remember last time I pulled a tcase the drive train was outside the vehicle.
I did not need a puller. I was able to muscle it out laying on a creeper. It's not a super heavy case (guessing 50-ish lbs?), but the uneven weight distribution makes it a challenge to deal with working from underneath. If I did it, so can you!
Perfection! thanks! I am sure you will see how it goes on my build. Pretty sure I have a bad nose cone bearing for the front output. hearing a-lot of noise in 4wd more so than it was. Like I said I have a spare outside the engine that I can use.
Sometimes a floor jack a block of wood and a few good ratchet straps will give you a good shot at a solo removal without too much drama.
If the work can be done on the jack/block/strap combo it can make it easier to align and push back in. That isn't always possible depending on what needs replacing.
For my Orion, I made a ugly butt functional cradle that fits on my regular floor jack. It makes removing the transfer for one man job otherwise the Orion’s pretty heavy.
It helps if it is nice and slippery w/ 90W sprayed all over the outside!
Snow Bucky Glamour Shots
Some PO long ago removed the under-the-truck spare tire carrier. I decided to fab up an interior mount to hold the spare safely. I used some flat stock and some 1” square tube. A couple of J hooks and wing nuts and:
Yeah, I know it would not impair my rear view as much if I had mounted it on the driver’s side, but I can see out just fine and the passenger side location may help even out the cruiser lean.
with this do you have a picture of the set up? how was it attached to the body?
