- Thread starter
- #81
I really do enjoy reading about your problems. I'm looking at doing a boosted 3rz with a Megasquirt ECU and it's nice to see all this information!
If you have the coilpack version - throw EDIS with a 36-1 wheel on the crank and a sensor pointed at it, and you'll be ready to go with MS1 easily.
Those coilpacks, I believe, are the same used on the 7mgte which are also the same used on the JDM late model 4agze.
Those coilpacks work great with EDIS and give the install a nice stock look. (I ran a smallport JDM 4agze on MS1/EDIS).
Make sure to at least get a V3 board.
If you have a 95-2000 3RZ then I assume you have the bosch style top feed injectors, I'm not completely sure on their stock size, but if you're going mild boost, I might have the right injectors for you sitting around (low ohm supra/mr2 turbo 440 cc/min).
