- Thread starter
- #141
Took me 8 hours by myself straight through taking my time, including disassembling and lubricating the front leaves. Finished after dark
I’ll have to shorten one steering link now that the angles changed and I’ll retorque everything in a bit.
Can’t say enough about how much it improved ride! I don’t know if that’s due more to what I put in or what I took out. My wife was happy, said it was like a different vehicle. I was especially happy with the back which was always pogo-ing around and jarring. Now it’s as good as it can be in a 90” wheel base vehicle. When they say soft ride they mean it!
For the front, the bilstein I got was the one they recommend for 2-4” … which was the same size as my 4” lift shock. It doesn’t have a ton of compression so I’m going to either swap it for the shorter one or go with the Ford shock tower mod.
Very happy with the KYB shocks and the skyjacker springs. L20FS and L20RS. The skyjacker bushings were noticeably more flexible than what came out of it and than some energy suspension bushings I had bought on amazon just in case and will return Monday. Also the energy suspension bushings were kind of a sloppy fit with the skyjacker spring eyes.
For lean I looked at the springs and biased them to the driver side. They were very close but it wouldn’t hurt
Lift before and after from fender to axle center. You can see the blue tape marks on the fenders
DF 23.25 …… 21.0
PF 23.5 ….: 21
DR 22.75 …: 20.75
PR 23 …. 20.5
It dropped it about 2.25" in the front and back. Now part of that was probably the Rough Country springs being more than 4" but I would say this is a 2" lift.
I’m soooo happy with it
I don’t think the pictures do it justice. Looks much more stuffed than high mud truck. You can feel the lower CG while driving
One thing to add, the rear had 2 degree shims with the 4" lift. I had reused these with the 2" lift because I had read they would be needed. Checking pinion angles once it was back on the ground I realized I did not need them and ended up pulling them. These shackles are stock length. If I had longer shackles, which may give more travel allowing for a longer swing, that would push down the rear spring eye and change the angle.
Pulling the shims took a little time, not because it was hard to jack it back up, support the frame and lift the axle while loosening the U bolts, but for what ever reason I couldnt get one of the pins into the hole until I fully took it apart. Something about the u bolts and the other spring being attached was fighting me. I should have removed both tires and loosened both at the same time, but didnt want to while working alone incase something dropped and initially tried to avoid it.
DF 23.25 …… 21.0
PF 23.5 ….: 21
DR 22.75 …: 20.75
PR 23 …. 20.5
