ufg8r
About time you fessed up!
Great build!
You have the blueprint for very similar mods I have in the works for mine.
Thank you for taking the time to document your progress.
Great thread. Haha, I just did the opposite. I (very sadly) sold my FJ62 for a GX470...
Ahh okay, thanks!I believe the HF castors ended up being a squeaky annoyance and is not recommended. Just buy the $60 kit from MT and source the Isolator online with the Toyota part number.
Where I differed on the install was by NOT using FJ Cruiser upper spring perches (something like $60/each, no thanks). I was brainstorming on how to keep the spring centered in the upper perch, and came across an idea at Harbor Freight (yikes!).
Solid plastic caster, 5.25" diameter, $6. It's not holding any load, it's just keeping the spring in place and centered. The spring is riding on the metal upper perch where the airbag used to reside.
Another pic, installed:
Works great, no creaks or moans from the the rear suspension...and should be very durable in this role.
So this takes place of the conical upper spring isolators...
I made my own lower spring retainers - The springs sit directly on the 'bump' on the axle where the airbags sat, and I bolted on a metal retainer to hold the springs down.Did you use the Metaltech kit for the bottom?
Also, what size bolt did you use to bolt the caster to the body underside?
^^^ Thanks!
For a quick update post here at lunchtime...here's a shot of the rear WeatherTech cargo mat, cut out for the tie down points and 3rd row seat attachment points:
Can't take credit for the idea, someone else on here (I believe, maybe Club Lexus?) posted a similar picture...and I thought it was a great option.
I'll try to post about my front suspension install, and my custom trailer hitch receiver "install" tonight.
- Brian
whats the parts number for the weather tech mat you used?
