Did you cut a notch in it? I’m using the Dobinson LSPV bracket, but the rod contacts the upper control arm and prevents driver side droop.
Same here. Guess I gotta do another Phil mod
Dosnt sound like something I would do but honestly I dont remember.
This is what we are talking about right?
Yup, that.
My rod is currently contacting the control arm and it does droop some with the axle as it’s still connected with the pumpkin.
One of these days, I may pull the LSPV, but braking still seems adequate for now.
If you feel your braking is adequate I would not touch anything.
DITCH IT. Stop fn with the LSPV and throw it in the trash!!!Phil do you think it's worth the extra effort to build in some adjustability? Wondering if you are still running yours in that fixed position (all the way up).
I removed my LSPV and all ABS. With that said, for my set up no adjustability is needed or wantedPhil do you think it's worth the extra effort to build in some adjustability? Wondering if you are still running yours in that fixed position (all the way up).
It takes an effort to hit the search button... dat simple.What does it take to bypass the LSPV? Already trashed the vintage ABS system
Born a leader I see so helpful!It takes an effort to hit the search button... dat simple.
Imagine those who spent the time posting the info. in the past on this topic only to find out ppl are incapable or unable to extract those info....luckily we have a forum to help with that...Born a leader I see so helpful!
Helpful kind of guy. Aren’t ya!Imagine those who spent the time posting the info. in the past on this topic only to find out ppl are incapable or unable to extract those info....luckily we have a forum to help with that...
I have no sympathy for lazy pplHelpful kind of guy. Aren’t ya!
I am trying to be helpful, but again, you either want to be help or you rather be Spoon-feed...Helpful kind of guy. Aren’t ya!
