Awesome! Thanks for the detailed answer!sure.
this is a 3-stage wet sand process and 2-stage compound buffing.
started off with 800 grit sand paper for 5 mins with minimal pressure (stopping every 30 seconds to clean them off and reapply water - using spray bottle)
next is a 1500 grit sand paper, same process for 5 mins with minimal pressure (stopping every 30 seconds to clean them off and reapply water - using spray bottle)
last is a 2000 grit sand paper, same process for 5 mins with minimal pressure (stopping every 30 seconds to clean them off and reapply water - using spray bottle)
for compounds i used Chemical Guys V-series,
-started with V32 (aggressive compund)
-finished it off with V38 (best for final polish)
lastly the ceramic coat I used was Avalon King.
Ceramic Coat flashed in approx 60 seconds since here in Vegas the air is really dry, buffed it off using a clean microfiber towel and did it for 9 times - 9 coats. why 9 coats - this is part of the front/fascia area and is really bound to get hits from rocks, pebbles, sand particles etc from daily driving - might as well overkill it. lol.
i took my time doing this, took me roughly 2 and a half hours for the whole thing start to finish.
