I've been driving my 71 fj40 quite a bit lately to work. I drive to work in the dark and drive home in the dark. Between the rain, drizzle, fog, etc, here in the NW winters, I finally got fed up with the amount of light coming from my stock headlights. So, I ponied up for some new roundeyes. Since I was going with the upgrade, I decided to buy the headlight harness kit as well. It bypasses the light switch and draws the current straight from the battery. I did a little review here on Mud first, but most people simply upgrade to the Roundeyes. So I figured I would detail my experience with both the headlights and harness together.
Links to where I bought stuff:
Roundeyes - 7" Round Toyota® Landcruiser Conversion Headlamps - Toyota Headlamps by Roundeyes™ Inc.
ARB/IPF headlight harness - TPI4x4
Summit racing - summitracing.com - we'll get to this in a minute...
I started off by pulling my rig out of the garage and taking a picture of the stock lights. I pulled it back in and put in the new Roundeyes. They are very nice. It was as simple as removing the bezel, loosening 3 screws on the headlight retainer ring, pulling out the headlight, unplugging it, plugging the Roundeye in, putting the retainer ring back on and tightening the screws. That's it! So easy, a caveman could do it.
I pulled back out and took another picture. The difference in light output was tremendous. There really is no comparison. Unfortunately, I am no photographer. I took pictures, but they don't do it justice.
Next, I wanted to install the ARB/IPF harness. Again, this was incredibly easy. I would have taken pictures of the process, but there is really no reason. It is a plug and play harness. You attach 1 wire to the positive on the battery, 1 wire to the negative on the battery, find a place to mount your 3 relays, and then plug the harness into the stock headlight wiring harness. It uses the stock harness to switch the relays. The relay wiring then plugs into the back of the headlights. This is where I ran into the one snag I had with the installation. You have to get the 3 prong plug into the headlight "cup" for lack of a better term. I believe on newer rigs this is not an issue. But on mine, I have a sealed cup with a small hole for the stock harness to go through. I had to open up that hole quite a bit to get the 3 prong plug into it. It was fairly simple with my drill and dremel tool, but I just wasn't expecting it.
I backed my rig out of the garage one more time and took another picture. The difference was notable, but not as dramatic as changing to the Roundeyes.
1st picture is stock headlights
2nd picture is Roundeyes only
3rd picture is Roundeyes with the harness
Again, I'm not a photographer and these pictures don't do it justice.
