I searched the tech forum and found bits of info here and there. I am hoping to summarize here.
(Note: this all comes because I am putting an H55F into my 1978 FJ40 (no rear axle PB) and I want to make an intelligent choice regarding my transfer case/parking brake needs. I have access to a split TC with a PB attached. I can source a TC without a PB easily.)
The options for a parking brake on an FJ40 are:
1. OEM transfer case mounted on one-piece TCs
2. OEM transfer case mounted on some Split TCs
3. OEM Rear axle mounted on later FJ40s
4. SOR/MAF (or other) kit to add PB to a non-PB transfer case
5. Rear disc brake conversion that includes a PB
6. More esoteric solutions like line locks, driveline disc brakes...
Is there anything else?
Here are the "issues" as I see them:
The TC mounted options shorten your rear driveshaft.
Axle mounted OEM would require cable/lever mods on a 40 that didn't have that stock. Would "give back" 2-3" of rear driveshaft length.
RDB conversion will require cable/lever mods as above but gets you disc brakes in addition to the PBand extra DS length.
It seems to me that sourcing a late model rear axle with parking brake might be the "best" solution to maximize rear DS length and minimize cost and mod work.
Thoughts?
Thoughts?
