What are the rough costs on the DIY 4x4 Labs Rear bumpers? I didn't see any info on their websites.
This is the info i got from Luke a while back when i asked. There is also an email address on their website or you could just call and talk to them about what you would like.
I copied a snippet from our price list for the
rear bumper. Let us know if you need further info.
thanks,
-luke@4x4labs
Rear Bumper Kits
Basic bumper- kit $495 Welded and finished $895
1 main bumper shell
2 sides
2 side top tubes
2 d-ring points
towing crossmember
receiver
Single swing out bumper- kit $895 Welded and
finished $1375
1 main bumper shell
2 sides
2 side top tubes
2 d-ring points
towing crossmember
receiver
1 large spindle assembly
1 swing arm assembly with 4 sleeves
Latch and latch plate
1 gas strut with ball stud
2 stoppers
Double swing out bumper- kit $995 Welded and
finished $1495
1 main bumper shell
2 sides
2 side top tubes
2 d-ring points
towing crossmember
receiver
2 large spindle assemblies
2 swing arm assemblies with sleeves
2 gas struts with ball studs
3 stoppers
15. Accessories
Tire holder- kit $125 Welded and finished $225
Swing out clamp bracket
Main upright
2 gussets
side clamps
top cap
3 hole tire holder
square tube receiver
3 wheel studs
3 lug nuts
Hardware
One, two or three gas can- kit $195 Welded and
finished $395
Main upright
2 base gussets
2 tubing hoops
tube spreaders
bottom plates
2 basket gussets
License plate bracket
Hi-lift bracket with standoff
Ladder #1 – kit $150 Welded and finished $350
2 Base tubes
2 rungs
Ladder #2- kit $175 Welded and finished $375
The first rung on this ladder is sleeved just
like the swing arms for a third accessory like
gas cans or a cooler. It can be removed for
regular access to the ladder.
Main hoop- long, you cut
1 round rung
1 square sleeved rung
Cooler basket- kit $225 Welded and finished $425
Main upright
2 base gussets
2 tubing hoops your supplied dimensions
tube spreaders
bottom plates
2 basket gussets
ARB fridge basket- kit $225 Welded and finished $425
Main upright
2 base gussets
2 tubing hoops
tube spreaders
bottom plates
2 basket gussets
Bicycle rack, 2 bikes- kit $195 Welded and
finished $295
Main upright
2 base gussets
Rear tire plates
Rear tire plate crossmember
Rear tire hold down straps
2 skewer tubes
2 skewers
Safety hook
Top cap
Logo plate
16. Separate bumper parts
*Main Shell- Formed and plasma cut bumper shells
for FJ80 and FJ60 $185
*Uncut formed main shells 72” wide- $125
*Formed laser cut side skid plates- $125 ea.
*HD Spindle assemblies- $95 ea.
*Swing out assemblies- HD spindle assembly,
sleeved swing arm with gas shock, ball studs and
stops - $225 ea.
*Accessory bracket clamp- $25
*Towing receiver- $25
*D-ring tow points- $30 ea.
*Hi-lift bracket- $25
*License plate bracket- $10
*De-sta-co 4000 lb. Latch and latch plate- $95
*Gas struts 120 lb. $25 ea.
*Ball studs $2.50
* 6" or 8" Gusset $9
*Accessory carrier retrofit sleeve/clamp kit- $29
*Using our retrofit sleeve and clamp kit our
detachable accessory system can be retrofitted
for use with any other rear bumper system with a
2” swing arm (ie. Kaymar, Slee, Man-a-fre, etc.)
