I recall someone talking about using an oil supply restrictor pill. I've used them on turbo subaru builds before. My truck averages 75 psi on the oil gauge at temp/load. I'm thinking thats going into the supply line and if you look from a fluids standpoint, that is probably VERY high pressure on that journal after its pushing 75psi into a small diameter line. My CHRA was pretty beat up when i pulled it. Having it inspected now by a borg shop.25k miles on my kit and overall its been great. I've been daily driving it since the turbo was installed with minimal issues.
Some problems I have had (and some I'm still having):
Some feedback/lessons learned:
- First thing that happened was trouble holding boost. Got a smoke kit and found quite a few leaks but it ended up being the EGR Modulator. I saw that others like @CJK have had this issue with used modulators but the odd thing for me was mine was brand new with the full rebuild I did in 2019/2020. I bypassed & disabled the EGR system and everything has been great. There were various other leaks I tightend up, the smoke machine kit is great.
- I had an oil leak from my turbo supply line after the first few heat cycles. Tightened it all up and no problem since.
- I have the same "compressor oil sweat" that @Wompom has on the bottom of the compressor housing. I thought it was the loose oil supply but persisted after. Nothing leaking from the oil drain either, and I tightened up the compressor housing with no luck as well. I take apart the intake every ~5k miles to check on things and there's always oil in the silicone elbow feeding the compressor. I added a dual catch can kit but I get almost no oil in the can feeding the turbo intake, lots of oil (comparably) in the PCV catch can though, and still the same amount of oil in the intake. I'm starting to think its an oil drain issue backing up oil and pushing it past the bearing but don't really have a way to test that.
- A few times (but rarely considering how heavy its used) this summer I would start the truck like normal and 15-30s later it would slowly stumble and stall. It only happened on very hot days when the truck was already warm. Every time I restarted the truck I would let the fuel pump prime the system then it would start up fine. I've figured it was a fuel pressure VSV issue but maybe I should be checking compression. I'm about to pull the plugs for the first time since turbo install so we'll see what those look like too.
Overall I love the turbo 1FZ though. I'm considering selling the 80 for a new cruiser that fits my family's needs a bit better but I will definitely be building another turbo 1FZ in whatever I replace it with. It pulls like an absolute weapon when the turbo spools and it honestly seems like the power on tap is endless sometimes.
- I should have gone with a lamba AFR gauge and vacuum/boost gauge from the start instead of an old school wideband and simple boost gauge.
- The smoke machine kit is a wonderful tool.
- The turbo blanket is fantastic but I wish I had ceramic coated as well, the heat is no joke.
- Despite all the heat, I've never had an overheating issue. I agree with others that the intercooler isn't required with this setup but I will be installing one moving forward.
- Since installed, I've never had a single CEL so the OEM ECU definitely can handle it. Not surprising since it runs quite rich all the time. Similar to the intercooler, I'll be doing a Haltech 2500 moving forward.
Borgwarner did send a warranty exhaust housing for replacement after they saw what mine had done.
Curious about the oil restrictor idea. Anyone have thoughts? @scottryana @haulin auss @audi2nr
Per Garrett on their journal bearing turbos (i know not apples to apples)
Journal-bearings function similarly to rod or crank bearings in an engine – oil pressure is required to keep components separated. An oil restrictor is generally not needed except for oil-pressure-induced leakage. The recommended oil feed for journal bearing turbochargers is -4AN or hose/tubing with an ID of approximately 0.25”. Be sure to use an oil filter that meets or exceeds the OEM specifications.
Trying to find a good info brochure on the turbo. Some of the BW turbos have a restrictor built into the inlet, which would mean that the supply is not the issue, but the drain not being able to keep up, or pressure pushing back up from the crankcase.
also check out post #4 on here - could be the drain, not the supply
