NO!!!! BAD NLXTACY!!! Engine driven compressor mount for the 1HDt first!!I know I know, turbo first!!
Not opposed to going with an auto that bolts to the cummins to start, doesn't have to stay Toyota. Then just need to go auto trans to Tcase. Suppose I could just use the NWF Black Box to do that though.
Nice project for a good cause though. If I wasn't married I'd look at switching to a manual trans but as is it's not in the cards![]()
Same engineCurrently looking like this. Note the little empty space next to my AC compressor. There should be a wits end bracket in there holding another compressor. I will even drive this thing to you if you wish.
Say the word and I will start driving!!! Nice 77Aren’t you in Georgia?!?!
I have the 77Series here so I’ll go thru and see how it can be done. I have a 22R Mount I’m already working on
Im no expert but i think thats an input
Another vendor that had these plates had issues with oil transfer from one to another due to those seals are really only directional. Solution was 2 seals one in each direction. FYI. Hope someone that actually had the issue chims in. I don’t use this product and just going from memory.
@cjmoon been talking with quite a few folks about this and no one has brought up this issue. I’m all ears though.
So, oil leaking, if an issue, doesn’t have much to do with the adapter. And isn’t the transfer case a sealed unit? I guess I could kick it over and see
But if you REALLY want/need two seals, the adapter itself doesn’t care.
I will clarify this concern. The early adapters did not include any seal in the adapter plate. @thegogglesdonothing was the unfortunate victim of that design flaw which resulted in trans fluid migrating from the NV4500 into the HF2AV causing the NV4500 to burn up. The input shaft seal on the HF2AV seals fluid on one direction...its designed to keep fluid inside the case...they don't do as well as preventing fluid from getting in. The solution was to make the hole in the adapter plate smaller and the exact same size at the OD of the same seal that is used on the HF2AV input shaft. You then take a 2nd input shaft seal and press it into the adapter plate in the opposite orientation to keep fluid from migrating out of the NF4500. Since that revision, no one else has had any issues.Toyota transfer case is sealed. If there is a leak it’s 100% not because of an adapter.
Dude, had this project started before the Turbo, I would have passed over the 96 land cruiser and dropped that money into my 93 to prep for diesel.
Sadly, well only figuratively, I’m planning on selling the 93 and pruning the money tree heavily to add a 911 to the fleet.
But I’ll keep an eye on this. Haven’t found the right car yet. I may end up being fickle
So total of 2 identical Toyota HF2AV Inputs seals. 1 in the normal position in the transfer case and 1 in the adapter plate but flipped 180 degrees.
I’m good at one thing.
His and hers.Not opposed to going with an auto that bolts to the cummins to start, doesn't have to stay Toyota. Then just need to go auto trans to Tcase. Suppose I could just use the NWF Black Box to do that though.
So what about those of us who want to keep an automatic?
The Cummins uses an adapter (flywheel/flexplate housing) to mate engine to bellhousing. Your only an adapter away to all types of possibilities. Plenty of them out there already for autos. AA has a TC adapter to mate a 4L60 and 4L80 to HF2A. Mainly for the LS swap guys.Different problem looking for a different solution. That requires a bellhousing that I’m not currently equipped to take on.
Easy just use a GM trans and there are already GM auto adapters to Toyota TC's. Marks makes them.
Yeah the 4l60e behind a diesel would be a nightmare. The 4l80e can be built to hold just about anything.LS swap guys could possibly put down 600 lb/ft of torque but they do it ~5,000rpms. Much different when it's putting down that power at 1600-1800 rpms. Those GM autos won't be very reliable behind even a mild 4bt much less a 6bt. I know this because I run a 700R4 which is the same as a 4L60. I haven't grenade'd mine yet, but I spent may too much building that bag of turds.
