Wheels that work, part numbers (1 Viewer)
Another shout for SCS wheels. Inspired by @cruiserpilot I went a slightly different route with the Gen5 wheels vs the F5. This was in large part due to availability where I am, but I'm very happy with the look. Details are: 9"x17" 3.5"BS (-38mm offset) wrapped in 285/70R17 KO3s. Vehicle is sitting on a OME lift (previous owner), though I don't know the specs.
Another shout for SCS wheels. Inspired by @cruiserpilot I went a slightly different route with the Gen5 wheels vs the F5. This was in large part due to availability where I am, but I'm very happy with the look. Details are: 9"x17" 3.5"BS (-38mm offset) wrapped in 285/70R17 KO3s. Vehicle is sitting on a OME lift (previous owner), though I don't know the specs.View attachment 3735004
That's got old-school dish to it. Nice! Didn't realize they had added a design. No idea what that colour is, but
very cool!
Love the wheels!! do you have spacers?
did you have to re-gear given these are 17's and 70" tall tires?
Thanks.
Thanks.
Thanks. No spacers required. The -38mm offset (9" wide with 3.5" backspacing) seems to work out just fine, at least with the small lift I have. I was coming off a 10 year old set of Goodyears Wrangler Duratracs that were 33"x12.5" R15 (stock wheels). The 285/70/R17 works out to be just slightly shorter (32.7") and more than an inch narrower (11.2"). In terms of re-gearing, I'm 95% sure I'm stock. Previous owner may have re-geared, but based on the speedometer readings I get vs GPS speed I doubt the ratio's have been changed. Full disclosure though, my LC is 95% on-road.
I took a chance on a set of 16” steelies from a 2017 Tacoma. Research showed the modern truck 106mm hub bore wouldn’t be enough to clear the front hubs, but when I mounted them up, all 5 cleared. Snug, but fit.
Not sure if a QC issue or most modern steelies are actually measuring larger than factory on the hub bore, so take at face value here.
These look great.
Here are the Nomad Arvo 17 x 8.5 -25 rims. I have stock axles, no spacers and no modificaations to the width. The tires are 285/75 r17 BFG All Terrain KO3. My suspension is a new OME heavy / heavy.
This tire is 33.8" x 11.3" per BFG
I would have preffered a simple steel rim but this is really the only wheel I could find with the extreem by todays standards offset.
full story here:
full story here:
those look really good! nice find
