What kind of transmission is this? (6 Viewers)
Just measure the overall length.
Overall Length Front to Mount Center Pan Bolts
TH200=28.25 22.25 11
TH2004R= 28.25 27.9375 16
TH350=27.625,30.625,33.625 22.25 13
TH400=29,34,38 27.9375 13
TH700=30 23 16
4L80E=32.5 30.375 17
Powerglide=25.3125,28.3125 22.25 14
There are no promises, but it seems to work for me. On a side note, one way to tell between a 200 and a 2004r is that the 200 mounts with 6 bolts rather than 10. I am assuming this is a chevy trans based on your previous posts. If its a ford or something else, let me know and ill throw another chart up. Good luck, Eric
Th350
This should work...
........Overall Length.....................Front to Mount Center Pan Bolts
TH200=28.25.....................................22.25..................................11
TH2004R= 28.25................................27.9375...............................16
TH350=27.625,30.625,33.625.............22.25...................................13
TH400=29,34,38................................27.9375...............................13
TH700=30.........................................23.......................................16
4L80E=32.5.......................................30.375.................................17
Powerglide=25.3125,28.3125..............22.25...................................14
Is that tranny a 2 wd unit because if it is you have already ran into some problems. Like not having enough output shaft to go into a tcase.
That's a th350 from a 4x4 set up. To get the t-case on it you need the adapter to go from th350 to either a np203 or np205 (different adapter.) I could sure use one of those short out put shaft jobbies, myself.
