What have you done to your Land Cruiser this week? (32 Viewers)
I installed a ARB HDAL kit, Heavy duty air line kit. Not that heavy duty and while tightening a swivel bushing it broke off, So i had to run for a hose shop on a Saturday to have a new one pressed. I received my 6amp guess charger so that is up next, i should do that this week.
Rebuilt front and rear axles and installed with new 3.70 gears, New brakes all the way around with new spring bushings with erasable pins . New tires PJ,s scorpion a/t 31x10.5. Next in line is all new door window rubber, felts and wing vent Line X the in side and replace the old seat with new ones,
Oh all most for got the almost new 2f and h41 4 speed sitting on my shop floor waiting to go in:flipoff2:
And in doing all this and drive it back and forth from work:beer:
FINALLY got my seats mounted and made a todo list!
rear quarter panels
rock sliders/steps
bumper front then rear
need to find out why my dash isnt lighting up
also need a new driver door and to get new weather striping on the hard top
a radio will be nice one day as well!!
^^ those arent in any order and if anyone reading this can help me out w/one of those goals im all ears!! send me a PM (or facebook me Zack Heard from the University of Alabama)
Hi All:
Oh, this weekend I installed the new long-travel shocks in the rear, bolted-up the lengthened front drive shaft, re-installed the skid plate, and patched a hole in the "wind jammer" (rear curtain.)
Need to re-locate the front turn signals and trim the front fenders to clear the front tires (moved the axle forward about three inches.)
Regards,
Alan
Put the OEM steelies back on. With 33x10.5 KM2's.
Fitted the ARB Winchbar to my 43 this week. HID's to follow.
this week 75
installed 6.2 trany and transfer ,put the body on and proceeded to wire 6.2 to tlc. started fabing fan shroud will work on that today
This week I purchased five Swamper TSL's of the 32x9.5x15 variety, a big step towards my 'functional Cruiser.' Check out those nasty lugs!!!
Installed the new drive-train for the second time to check to see if the mocked-up body lift would give me sufficient clearance for the drive train. 1" on the nose and the height is perfect, whew!
As long as it was all mocked-up in there I finished up the x-member, and clearanced it for the front d-shaft.
Feels like this project is finally starting to come together :bounce:
I made a small master switches control panel,using the best top console,still have to order push on/off small switches for the roof rack lights.
Hi All:
Among other things this weekend I trimmed the front fender lips for better tire clearance since the front axle has been moved forward about two inches. Now I need to figure-out what to do about turn signals.
Regards,
Alan
Since I'm still sans a front axle for my SOA, I tackled a couple of other to-do items instead. I installed my 4Runner master brake cylinder for my disc brake conversion. Went on quick and easy after I talked to Oldnslo and got a couple of clues. I then tackled the rats nest of wiring the PO left me and pulled out the partially installed Painless kit and what was left of the original harness. Now time to read the new and improved Painless install manual and get familiar with it!
Finished the hell creek 4 inch. had to go back and put the 4* shim in that my buddy found in the pass seat on our test drive:doh:
new u's in the rear driveshaft. Put that back in time and found my speedo problem at the same time (knot head po)
put it in the shop for a tune up, points, plugs, cap, rotor. adjust the carb.
I can built the :censor: motor trans tcase rewire the whole truck. but I can not
tune it. I am an old pro at getting out of tune:crybaby:
gion to see the truck doctor tonight to get my 35' and be ready for skyline.:steer:
