What have you done to your 200 Series this week? (18 Viewers)
It does, but you have to watch the rear hatch spoiler. It does hit the box even when it’s positioned as far forward as it will go. I believe I have the skybox 18.
interesting, i have the skybox 18 and mine clears with the factory bars with no issues.
No the bars are not adjustable up or down. It’s worked quite well for me so far. Running an awning, 4 gallon rotopax, light bar, and occasionally Yakima rooftop carrier. No plans to run a RTT so I don’t think I need anything perfectly flat.
Simple! I like it! How high do these crossbars sit above the factory rails? Looks like maybe only an inch ish? I have exactly 2in to clear my garage! Looking to optimize!
Didn’t realize I opened a can of worms here but I’ll try to do my best to illustrate. The bars sit about 1” above the side rails. Wasn’t sure how much curve there was to the rails so I set something relatively flat (my broom) across the rails to demonstrate. It appears that there is about 1” of difference from front to back. If my broom measurement is accurate. Lol. Hope this
Good ideas get attention! Thanks a ton for taking the time to do that!
Replaced my power steering pump. It took a dump during some hard driving. I'll be installing a bigger cooler with a switched fan that I can turn on/off in the cabin of the vehicle
Installed RR Vortex bars. After I discovered previous owner had left me a surprise under the attachment point front passenger, I had to drop headliner to replace a mangled threaded receiver clip thingy (whatever you call that) and the yellow tubes but other than that it was relatively easy. I took my time and did some major clean up in my rain channels up there so when I put it all back together I'd feel confident of no water intrusion. I used permatex #2 and some blue loctite and feel pretty good about the set up, fingers crossed.
I have the same pump and mount and I wanted to do the same thing. Can I get some additional pictures? Also did you hard wire it?
I liked this set up too. I have the same compressor and mounting it on a Slee tray never occurred to me. It is hardwired. You can see the cables in wire loom going from the compressor to the battery.
Man I wish I would have found those before I bought the ARB hooks. Those are sharp.
Saw them on one of the Ed Martin builds and knew I had to have them!
Truck was down for the count and needed hay for the goats. Was able to easily squeeze in two bales with room to spare. Needless to say, a thorough vacuuming is now due.
How are the fuel cans secured to that tray?
Its with the Baja Rack Jerry Can mount. seemed like the best option I could find to work with Wavian cans. It’s designed to mate with their roof rack but was an easy install to pair with the Dissent Offroad accessory tray. Makes me appreciate the R&D and weight savings that Dissent @benc provides with their use of aluminum , the steel Jerry can mount is a porker lol.
  • Like
Reactions: LCT
I'm shopping front recovery points and found those the other night - really like them. Look great on your rig. Are they rated?
No idea what they're rated to. Maybe @ZRTacticaits chime in. They're billet aluminum.
  • MSLX
