What have you done to your 200 Series this week? (35 Viewers)
I have both. The 2721 gave me one extra inch in the rear 23-23.5.
Exactly the same ride
OK. Perfect, as my next mod will likely be Drawers in back with stuff in them 90% of the time...so that extra inch will give me a bit of room to settle a bit.
Eventually, I'll go to 2723 when Slee gets around to creating a rear bumper... (his bumpers are HEAVY and AWESOME). :)
Thanks again for info.
Markupoop
I have the new 2721s. Used a few weeks! Pm me if your interested.
Thank you, but that's what I already have (2721s).
What I'm stuck waiting for is the front install kit for BP-51.
Sitting in my garage in their boxes:
-SPC UCAs
-OME 2721
-BP-51 Front and rears
-Rear Install kit
NO FRONT INSTALL KIT!! :bang:
It's dirty underneath from my last trail ride. Utilized the factory hanger mounts and left the counter weight on (if that is what that is). Could have tucked it more if I had removed the OE spare tire mounting bracket - food for thought.
Hope this helps you
Decided to black out my Rock Warrior Wheel Rings. Really like it compared to the polished aluminum. I just plastic dipped it. They will get scratched so I will just redo as needed.
Looks great - I think you'll be surprised how long that stays on there - its tough
True. I gouged the new bare rings in a few placed on the trails near Ouray, so this covered that up too. Just takes one can to do all four. It actually looks better on the black cruisers and when you can see the entire rig. I believer these rings actually save me from marring the wheels based on the way the where scratched- so not all for show after all. Easier to replace the rings (well, maybe not in the future- soon all the stock will be gone...)
Looks good.
Q for u... Were you able to screw the ring back on with the tires mounted? I've heard some have trouble remounting the rings with tires on... Keeping mine stock for now, but might play around with color if I don't have to take tires off...
I finally got my 200 back after putting on Iron man pro foam cell shocks and springs. I did an aligmment and got everything reset per toyota. It has a tendancy to oversteer or is very sensitive on steering. Any idea of adjustments or something we did wrong on the install?
You had Toyota do the alignment?
Please list all parts you installed
Sent from my iPad
you got it bud
did you check your tire pressure?
BP51s reporting in after day one.
Measurements from center of hub to lip
Front w/ 5mm preload L 22" R 22
Rear with 2720 L 22.5 R 22.5
Compression at 1
Rebound at 6
Sitting perfectly level.
Thanks #sleeoffroad for the BP51s and UCAs
#beno for the Oem hardware
And Kurt at #cruiseroutfitters even though I didn't buy from Kurt he was more than helpful with info. Dude, you have my next order (even if I don't know what it will be)
Can't forget #bjowett He's been sending me test shocks for a year. If it were not for him we would not have figured out what does and doesn't work on the 200. He now has some really nice inexpensive solutions for the 200 that in my opinion are really good. I'm shipping my existing setup to Amir in Boston and I'm sure he'll report his opinions too.
If it were not for MUD I'd be in a........(insert your most hated SUV)
looks great man - congrats
Compression at 1
Rebound at 6
That turned out really nice :cool:
Am I reading right that you have your front and rear adjustments at C1 R6?
Did you add 5mm of preload on the fronts?
what are you running / wheel / tire / current psi
