Can you please give us your front measurement from the center of your hub (or center cap) to the bottom lip of your fender?Good info thanks. No UCA. Thats an obvious improvement that I am looking into.
No upper control arms?
I know this was a big issue for me. Even with a small lift I had positive camber which could not be dialed out with a normal adjustment. There is very little adjustment in the lower arms. In addition I found that Toyota never really tried to adjust caster and camber. They adjusted toe and pushed it out the door. When I pointed to the obvious positive camber they pointed to the print out and said "it's within spec." In tight turns the outside tire would tuck under and wear the outside edge.
It was not until this week that I installed the upper UCAs along with the BP51s and sent it to a reputable, independent alignment shop (that does not sell tires) that they finally got the alignment in order.
Wish I had done the UCAs years ago.
Has anyone gotten a perfect alignment with a lift without UCAs? I mean perfect, not just because the printout says it's good.
Yep, you're definitely in UCA territory.Measurements from center cap to bottom of fender are;
DSF 22 3/4
PSF 21 3/4
DSR 24 1/2
PSR 23
Yeah. Lift is much higher than i thought. The lift is advertised as a 2 inch lift. What did i eff up.
You didn't eff anything up. Check that the suspension was torqued with wheels on ground. LCAs,sway bars, lower shock bolt. Any rubber bushing must be torqued at neutral height.
If not just save up for those UCAs. You won't regret it
TJ, read the thread listed below. try that first, then if that doesn't cure your lean, you can try to loosen the LCA bolts and retighten. be sure to mark the location of the cam adjusters before loosening anything up.
Cruiser Lean: "You've been doing it all wrong. Yes you"
DSF 22 3/4
PSF 21 3/4
DSR 24 1/2
PSR 23
First thing I would do is open the KDSS valves 3 turns (not more!!!!).
Just on the running board and make love to your truck, rocks it back and forth. Drive it 10 feet and repeat. That should neutralize the KDSS. Lock the valves and re measure.
If you are off take to the reseller ( don't remember who that was). OME makes strut spacers for just this purpose.
Since your drivers side is so wacked I'm thinking KDSS.
Talk to the experts. #sleeoffroad Christo and Amory and Kurt at #cruiseroutfitters.
