What have you done to your 100 Series this week? (46 Viewers)
Just thought I should leave this here: http://www.windcatchergear.com/
I also installed one of Nick's 14" bars on my Blueberry last Friday. Hooked it up to the high beam relay so I don't accidentally leave it on with the headlights
Photo?
I had two days in Anza Borrego south, near the famous squeeze. Hiked up to the wind caves. Clear sky, foolish moon, bright stars and a fine rest away from the city.
The the 100 fit through the squeeze?
Didn't have any when I posted, apologies!
Here's the bar on the bumper:
And here is the switch that I installed in the cabin:
And finally the slightly ghetto wiring to give power (black ground on battery, two red wires):
The one thing that had to be modified so I could retain use of the standard light tabs was a lot of grinding on the mounts that come with the light bar. I don't have pictures of it but I basically fully contoured the mounts to lay flat on the bumper's bar. The thing puts out a nice amount of light at night too :D
For a neater look, wrap it in spiral wrap.
Finished mounting and hooking up both led cubes from Nick, wired into the reverse lights and into a switch in the cabin. They are...bright.
I want some!!! Brightly shiny things are awesome!
Does anybody have an idea of a good mattress?
My idea of a good mattress is one occupied by a playful blonde....
Home Depot sells a 3 or 4 inch foam camping pad with cover for $40.
A full size bed memory foam mattress pad would be another option.
New tires :)
Not bad 875.00 out the door for Michelin LTX's + full warrantee
Sent from my iPhone, please embrace the typos
Dropped off my 06 to have the AHC removed and a 2.5" OME lift and drop down bracket from SLEE installed.
Next up: 1) install rear bumper from BIOR (fabrication in progress), 2) Install ARB winch bumper once lift is on, 3) install sliders being made by White Knuckle Offroad.
Drain/refill on the transmission this afternoon.
Got delivery of my new National Luna Split Battery Charging System - will install it much later on.
Spent an hour cleaning and scrubbing the DS seatbelt [that thing was black in some parts] and also scrubbing the door cards.
Much nicer :) .
...via IH8MUD app
