What have you done to your 100 Series this week? (49 Viewers)
Modernized the Accessory charging connection with the BlueSea dual USB. The cig plug next to it remains factory and switched with ignition for my inReach which is only powered while running. Did the relay mod for the factory accy outlets for always hot.
Also created a custom mount for my iPad navigation unit and inReach to sit together secured on the dash. I use various apps for navigation and the inReach app for too maps, messaging and tracking.
Timing belt replaced, with all moving parts, seals and water pump replaced as well. Good for another 100 K.
Almost had another truck hit my tail gate when it was open. It sat idle for a bit so all the lights turned off. So I added some reflective tape.
Good idea. I've thought about putting some whelens up there for a similar reason.
Cleaned MAF sensor, throttle body and did a Seafoam treatment and got nary a wisp of smoke from the Seafoam. Must be a darn clean engine!
Did the same stuff to my Saab Aero at the same time and got some good blowout! Stunk and smoked up the neighborhood and got some dirty looks from passers by. Oh well.
Now off to re-educate the ECU on the LC.
Put a tow hitch on the back, then accessorized the hitch with a 30,000lb tow strap, then accessorized the tow strap with a Jeep Cherokee. Pulled a guy out of a ditch is what I'm trying to say.
Leveled the front end, got my windows tinted with ceramic film, put on tundra 18"s, and plasti dip the grill and Toyota emblem.
How do the tundra wheels fit? Trying to talk wifey into letting me try it!!!
Cranked the tbars finally:
Before:
After:
Sent from my iPhone. Clumsy fingers may contribute to mistakes.
They fit great except you have to use stock hub caps on the front. I only bought them for the tires and will be up for grabs here in a few weeks though.
Used it!
installed dt headers 5 hour job really not bad. no more ghetto ticking from the cracked manifold YAY! sounds better too! :)
Installed a Yakima Holdup 2 on the Slee Bumper. FYI you can not fold the rack up or open the tire carrier/tailgate but two bikes will fit fine. The bike on the inside may touch the tire. I may incorporate an extension so that I can still get in the truck but need to find one with a screw in pin so there is no movement. Liking the rack so far. Super quick and the integrated locks are pretty awesome. Was considering the Kuat NV but the 20% off plus mail in rebate from REI bit got me.
Installed new eezi awn roof rack rails from Equipt because I simply wasn't happy with my Rhino rack pioneer rack.. These are so much more stout!! Very happy so far.
Going in about an hour to pick up my new Starter from Mr T. I'm 99% sure my contacts are fried.... Should be a fun install.. :-/
What about when you hang the 315 off the back? Will 2 bikes still fit?
Doubt it. The rack is expandable to 4 bikes which would give me three usable slots as is.
Sorry if its in a thread somewhere but what were you not happy with?
