What have you done to your 100 Series this week? (63 Viewers)
Rear diff fluid change. I purchased this with 170k, finally got around to changing it. The oil looked pretty yellow.. Little opaque but not dirty, but check how many shavings.
Bought an iPad and am trying out the 4" SeaSucker brand suction cup mounts. 120-lbs of force. Testing it out on my Tundra until I can get out to Moab in two weeks to slap it on the 100's windshield. So far so good on the Tundra. They actually have a piston you push that sucks all of the air out. They are designed for boats in the waves so I figure it will hold up to most of Moab. Bike racks too (not mine).
Bought an iPad and am trying out the 4" SeaSucker brand suction cup mounts. 120-lbs of force. Testing it out on my Tundra until I can get out to Moab in two weeks to slap it on the 100's windshield. So far so good on the Tundra. They actually have a piston you push that sucks all of the air out. They are designed for boats in the waves so I figure it will hold up to most of Moab. Bike racks too!
View attachment 3978218View attachment 3978219
I don't want to be behind you on the highway 😛
Decided to check my wheel bearings as part of chasing a “wah wah wah” I get from 45-55 mph. I repacked then 25k miles ago, and the Timken bearings only have 85k since new. No play at all. The nuts were hand tight. Right side black grease around the bearings. Driver side I was greeted with dark black grease on outer, and red on inner. Outer bearing was shot. I couldn’t get a good bearing today, the best was a Napa Chinese one. I’ll change it out next repack. I’m baffled how that bearing wore out so fast. I’m pretty anal about following the book on this job.
What grease did you use at last repack? If the red grease turned black that’s heat. Sounds like you know what from what but is there a chance you had them too tight? Toyota can’t provide a non Chinese bearings? I’m just going through my new to me 01 LC with 134K. Bearing repack is next up. Am I recalling correctly that the spindle nut is 55 mm?
I used Mobil 1. I couldn’t get a Toyota bearing for four days, and really needed to wrap it up on the weekend. I use the fish scale to get 12-15 lb of breakaway, and don’t pay attention to the torque.
Where did you buy the replacement sheetmetal? I have a small rust spot on the rear quarter underneath the rear bumper I need to repair. Same spot as yours just not as bad.
MEO Outfitters is doing the body work. He sourced it, so I don't have the numbers. I'll ask him when I pick it up.
I'm getting close to the 300K rebuild and checking my head gasket that may have started leaking
Thanks they do look pretty oem, minus the center console I ordered the set for a LC but apparently the console lid on the LX is much smaller. They had to do an alteration to get it to fit.
I learned about this company from this article
I ordered directly as the shop is not too far from me. If you are doing it online go to the customize now section. They only list a land cruiser so thats what I went for.
Been looking for some decent looking but not overpriced seat covers. This may be exactly what I need. I am intrigued by the tan canvas. I have a LX as well. When ordering for the LC it came with armrest covers?
The armrest and center console were a little extra. My price i believe was like $310. I would call them and tell them you have a Lexus i believe they said they measured my center console.
I detailed everything on this thread.
Well, it wasn’t every single other steering component possible... But at least everything is new I suppose 🤦🏼‍♂️
Before the OEM only crowd comes for me, yes I know. My girl is not getting cleaner, only rustier, but I’ve accepted that and battle it where winnable. And after 8 years of ownership at $4500 purchase price, everything from here out is aftermarket (non-engine related) until she croaks. If the rack goes in 2 years or even a year, it’s just a reason to finally say goodbye.
made new front skid, tweaked centre skid, painted / coated them both, refreshed the lower front arms with new bushes and BJ'S, cleaned and coated the lower arms!View attachment 3973890
Interesting. What thickness of steel did you use? I bought some 1/8" sheets earlier this summer with the idea that this would be something similar I would like to do to practice my welding on. That way I can make some ugly ass welds and no one would be the wiser.
Bought some parts before the end of the de minimus exemption.
Replaced hazard switch light bulb and also vacuum hose and related valve as mine was showing some cracks. In swapping out the valve, I made a mess as I did not realize how much power steering fluid would come out. :(
Did you have any trouble removing the old PS vacuum valve? Mine's in there tight and I'm hesitant to go full-gorilla on it.
Mine was on there pretty good too, and you will for sure feel like you’re going to break it, but mine did come loose. Same with the banjo bolt on top, thought I was for sure snapping that baby.
